Browse Forums Kitchen Appliances Re: Gas cooktop 2Aug 12, 2009 7:10 am We've had installed a 'normal' gas cooktop for use with LPG. There is no mains gas in our street. No idea whether the cooktop needed to be adjusted for the lpg. But it's working beautifully. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Gas cooktop 3Aug 15, 2009 1:11 pm You need different jets in them to run on LPG or natural - So make sure the jets are changed to suit the gas being used. DO NOT USE IT unless you have the right jets in it. Most new cooktops come with both types of jets in the pack - and the gas fitter changes them as required to suit the installation. If not they cost about $50 or so to change over. My daughter and son in law are about to start building, they are having a 600mm induction cook top and 900mm oven. It's personal preferance 5 12937 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20506 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3876 |
