Browse Forums Building A New House Re: Did anyone upgrade to Terracotta roof tiles? 7Jul 30, 2009 8:34 pm Rinny Hi, we've upgraded to Terracotta and it cost us $5,076. This is alot of money, but we figured it would save us in the long run. We asked the consultant at the brick company how much it would cost to re-spray faded concrete tiles, and while he wasn't sure, he thought it would cost approx $2K. So the reason we chose it is that it will be more fade resistant (therefore preventing the need for future maintenance) and it has better insulation properties. We also heard it will significantly improve the house re-sale value. Rinny, would you happen to know how big the surface area of your roof was in m2? Re: Did anyone upgrade to Terracotta roof tiles? 8Jul 30, 2009 8:44 pm gettingThere Rinny Hi, we've upgraded to Terracotta and it cost us $5,076. This is alot of money, but we figured it would save us in the long run. We asked the consultant at the brick company how much it would cost to re-spray faded concrete tiles, and while he wasn't sure, he thought it would cost approx $2K. So the reason we chose it is that it will be more fade resistant (therefore preventing the need for future maintenance) and it has better insulation properties. We also heard it will significantly improve the house re-sale value. Rinny, would you happen to know how big the surface area of your roof was in m2? Hmmm....well it's a 43 square double story house (The Nelson with M), so maybe about 20squares (not sure in m2) Maybe this link to the house details contains some clues for you?? http://www.metricon.com.au/victoria/hom ... fault.aspx Re: Did anyone upgrade to Terracotta roof tiles? 9Jul 31, 2009 3:06 pm Hi we building and for 40 2m we were charged $5000 but we got glazed too. Also this time we including sarking. Its a protection under the roof line of tiles, like foil stuff. Good luck Terracotta tiles by memory have a 50 year g'tee, check the concrete ones. Re: Did anyone upgrade to Terracotta roof tiles? 10Jul 31, 2009 3:29 pm Hi, We are considering upgrading to terracotta too. However, budget is tight and in all likelihood will probably stick with concrete. I would prefer terracotta because of its colour fastness. I have heard the matt finished terracotta tiles have a higher propensity to grow moss on them as opposed to gloss type terracotta. Concrete tiles also come with a 50 year guarantee (monier).. however, as others have rightly pointed out, the colour will fade over time (although the roof still performs a perfectly good job!). cheers!.. Re: Did anyone upgrade to Terracotta roof tiles? 11Aug 01, 2009 10:58 am Thank you all for the replies. Will wait and see what the quotes come back with. If it's a few thousand extra than that's fine but if it's more than 5k then Re: Did anyone upgrade to Terracotta roof tiles? 12Aug 07, 2009 10:00 am Just received a quote from Boral. To upgrade to terracotta it would cost an extra $5,400 which is around 35% more than the concrete ones Re: Did anyone upgrade to Terracotta roof tiles? 13Aug 08, 2009 7:33 pm Is it true that terracotta tiles are HEAVIER than concrete roof tiles? Re: Did anyone upgrade to Terracotta roof tiles? 15Aug 11, 2009 12:06 pm sparkycarla Hi we building and for 40 2m we were charged $5000 but we got glazed too. Also this time we including sarking. Its a protection under the roof line of tiles, like foil stuff. Good luck Terracotta tiles by memory have a 50 year g'tee, check the concrete ones. sparkycarla, are your terracotta glazed tiles flat profile or not? I am finding it hard to find flat terracotta fully glazed Have only managed to find semi glazed Re: Did anyone upgrade to Terracotta roof tiles? 16Aug 11, 2009 5:18 pm we got Terracotta, one thing you shouldn't forget is to add sarking. as Terracotta cracks more easily than others. with sarking it will help with any leaking problem in case of crack tiles. when ABC Seamless sent their inexperience yound guys to install our leaf guards, they cracked our beautiful tiles by stepping on the wrong place! I got this post on my blog if you need further info about sarking: http://building-our-first-house.blogspo ... nding.html Hi everyone I have a terracotta tiles roof When I climb inside the roof cavity I can feel that there is a draft inside the roof as the wind goes through the roof which is… 0 4968 We're looking at replacing the roof of a heritage listed home so it needs to be terracotta tiles, wondering if anyone has any recommendations, hints or… 0 1710 Do you have solar on the roof, because if its not a laying defect it looks almost like someone has been walking all over the roof in the mid section of the tile (weakest… 2 2135 |
