Anybody out there got any experience with installing a hot water recirculation pump ?
It's s small pump forcing the cooled down water in the hot water pipes back into the water heater, to avoid running the tap before hot water comes.
Browse Forums Bathrooms and Laundry 1 Nov 04, 2007 12:21 pm Anybody out there got any experience with installing a hot water recirculation pump ?
It's s small pump forcing the cooled down water in the hot water pipes back into the water heater, to avoid running the tap before hot water comes. My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Recirculation Pump 2Nov 04, 2007 5:51 pm No experience, other than a bucket in the shower
But I like this invention. Saves lots of plumping and wiring costs that some of the other systems that are around need. http://www.advecotech.com.au/Products_use_standard.htm And it's Australian made too - even better Steve Re: Recirculation Pump 3Nov 04, 2007 8:48 pm Interesting Yak,
Whats the payback time on something like that? Whats the initial cost? Re: Recirculation Pump 4Nov 05, 2007 9:41 am I knew about the Dux (http://www.dux.com.au/recirculation.htm) and Autocirc (http://www.carhil.com.au/autocirc.htm) pumps. Thanks for the third one Steve. Now I'll have to find out which one will suit best.... My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Recirculation Pump 5Nov 05, 2007 12:19 pm Well they say up to 10% water saving on the web site.
The basic unit is $487 and the mixer model is $838. So if you work out 10% of your annual water bill that would give you a best case payback period - and maybe 5% as a worst case - and you'd find out your payback period young Matt. Remember it is a long term product. But more to the point - it stops wasting good fresh water and if your in Brissy on Level 6 water restrictions, (which they may well soon be) it would give you a bit of water every day on to your prized vegie garden without even having to bucket it out from the shower or kitchen. Steve Steve That's brilliant would appreciate if you have you can locate the other doc so I can use it with my discussion with the building surveyor 10 19355 Hi There, Can you please share the feedback on heat pump hot water system. We have requirement to put the heat pump hot water as per the covenant. Which models are the… 0 5370 |
