Browse Forums Heating, Cooling & Insulation 1 Oct 17, 2007 1:07 pm I thought the collective wisdom of the homeone community might help us make the best decision as to what split system to get. It needs to be capable of cooling quite a large family, dining kitchen area - at least 60m2.
So far we are looking at Daiken, Mitsubishi Heavy Industries and Panasonic??? Daiken is quite a bit more expensive - are they worth it? If anyone is in the trade please let me know you opinion of what is best. Cheers Re: Which brand split system a/c 2Oct 17, 2007 1:12 pm Mudtrilogy, you should send a PM to MarkDHC, from Dynamic Heat Cool.
He visits the forum occasionally or visit www.dynamicheatcool.com.au. See if he can help you out with more information. In negotiating cooling for our new place, i was advised today that you require 1kw per sq of living space? So make sure you get the right unit suitable for the area. Good Luck. Re: Which brand split system a/c 4Oct 19, 2007 11:56 am Daikin in my opinion make the best reverse cycle units - yes they are more expensive, but the parts used in them are of the highest quality... if you want the best go for Daikin
With regards the size of the a/c unit required, we have a PDF file on the website that will help you determine the right a/c size for a room.. http://www.dynamicheatcool.com.au/component/option,com_docman/task,cat_view/gid,26/Itemid,44/ Dynamic Heating & Cooling - http://www.DIYheating.com.au DIY Ducted Heating & Cooling Systems DIRECT to the public Move your linen into laundry and access laundry from your present linen space 1 8441 Thank you. That is really helpful. Once we get the place done and passed for OC we can upgrade in the future once we get back on our feet and not paying mortgage and rent. 4 6167 Pay again? No retribution? Your glass has a specific performance get this app and see how much your windows are leaking, then challenge the supplier. 3 5055 |
