Browse Forums General Discussion Re: To extend or bulldoze/rebuild 8Sep 16, 2007 9:20 pm [quote]As Brittany has said. If you're block is reasonable flat, which ours is, then it shouldn't be a problem to remove. Worth checking anyway, if you're in Melbourne that is.[/quote]
We are in sydney, and will check it out. Thanks You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 21151 We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 14724 5 7074 |
