Browse Forums DIY, Home Maintenance & Repair Re: Best concoction for cleaning general area tiles? 22Apr 14, 2009 9:26 am Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Best concoction for cleaning general area tiles? 23Apr 14, 2009 6:37 pm Thanks craig I will purchase both before I move into the house. Tiler is there at the moment cant wait to see them when their all polished up Know where your going in life............... you may already be there Re: Best concoction for cleaning general area tiles? 24Apr 14, 2009 7:01 pm Grout Perfect If you have a film over the tiles try and mix up 50% vinegar with 50% water than mop on and dry off. You can also use a window cleaning solution. Supastar is a great product but it is for maintenance only but give it a go you do not really have to use a microfibre mop try the other mops instead if that helps. Craig so your saying supastar is for maintenance, what does this mean for ceramic tiles, should we be using something else for day to day cleaning? Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Best concoction for cleaning general area tiles? 25Apr 14, 2009 8:21 pm gave the floor a going over with hot water and vinegar and it has removed the sticky residue, just looks horrible! Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Best concoction for cleaning general area tiles? 26Apr 15, 2009 7:25 am billdsl Grout Perfect If you have a film over the tiles try and mix up 50% vinegar with 50% water than mop on and dry off. You can also use a window cleaning solution. Supastar is a great product but it is for maintenance only but give it a go you do not really have to use a microfibre mop try the other mops instead if that helps. Craig so your saying supastar is for maintenance, what does this mean for ceramic tiles, should we be using something else for day to day cleaning? For day to day cleaning YES use supastar neutral cleaner or any cleaner with a ph balance of 7 as your maintenance cleaner specially for ceramics and porcelains if the tile or grout is really grubby than you will need a prof tile cleaner first as we use high alkaline cleaners to restore than rinse out under high pressure. Craig Re: Best concoction for cleaning general area tiles? 27Apr 15, 2009 7:37 am Hels billdsl sounds like way too much effort lisanne, but i think ill look into a good mop, ive already become the vacuumer because of the dyson and its cool'ness hels i read on choice that they dont think steam mops are worth the box they come in and have done fore several years with no improvements lately, they might be chemical free etc, but in terms of removing dirt or grime a vacuum cleaner does a better job, although im sure they werent testing on porcelains Oh no, don't tell me I may have bought a lemon!! Ive got a steam mop and I think they are great Especially in the kitchen anything split or stuck to the floor will come straight off no need for hard scrubbing with the mop. I always vacuum first of course, The tiles come up a treat I was in Metro tiles they said steam mops were great for tiles aswell but not to use them on floorboards, something to do with massive amounts of heat etc will cause probs with the laquer. Living in Caloundra Thread****** Lovin my house all finished!!! Now tackling the HUGE task of the Garden- viewtopic.php?f=31&t=14782 Re: Best concoction for cleaning general area tiles? 28Apr 21, 2009 8:21 pm I see someone earlier on mentioned a steam mop and carpet in the one sentence. Please don't go there. And listen to Craig about tiles. He knows his stuff. cheers Col Nation For information on caring for wool and other carpet and upholstery go to www.woolsafe.com.au You should check your detail drawings, it may show downpipe within brick pier. 14 14720 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 17664 No, I even have sections of narrowness where the tiles won't slide up any further. When I manage some spare time, I might play around with the first DIY part of my… 7 5330 |
