Browse Forums Building A New House Re: New Fence - Boundary 2Apr 10, 2024 9:15 am shalastetok That sounds like quite a situation with your fence. Personally, I believe that if it's encroaching onto your property, it's only fair to have it rebuilt to sit on the boundary line as per your request. Tolerance is one thing, but 5cm into your lot seems a bit much. Perhaps consulting with fence installation experts could shed some light on what's considered acceptable in these cases. The fence install experts you recommend are from the UK. Not sure if that'll be helpful for someone in Vic. Re: New Fence - Boundary 3Apr 10, 2024 9:57 am Hi, It’s important to keep in mind that dividing fences have thickness, so it’s impracticable to expect them to be wholly constructed within the neighbouring allotment. Standard timber fence is approximately 153mm thick (post 100mm, rails 38mm, palings 15mm), if provided centre to boundary that would be 76mm inside your boundary. Blockwork fence is 190mm thick, or 95mm inside your boundary. Colorbond fence thickness is approximately 70mm (posts), or 35mm inside your boundary. If the entire fence is constructed within your boundary and this is established by an Identification Survey by a licensed surveyor, then yes, I would also expect this to be rectified or be compensated. First step would be to provide the neighbour with a copy of the survey and note your concerns in writing, and if no resolution is achieved, seek legal advice. Hope this helps! Building Designer | Sunshine Coast www.draftroom.com.au Building Standards; Getting It Right! Hi everyone, My lot has just been titled and during the settlement we found that the rear pegs were not visible. We requested for a re-establishment and pegging plan… 0 19280 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 47457 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16800 |
