Browse Forums Heating, Cooling & Insulation 1 Mar 06, 2024 1:25 pm I am looking at options for roof ventilation. Solar vents are very expensive but I have been told by a few people that whirlybirds end up squeaking and need replacing. Not sure if particular brands are better. Any recommendations? Would eve vents be enough to help cool a tin roof space down or will it still require a whirlybird? Thanks Re: Roof ventilation 2Mar 07, 2024 7:12 pm E-Vent Roof Ventilation - The Best Whirlybird | Get A Quote (cmiwa.com.au) No moving parts, sits on the roof ridge. Still needs eave vents. We have 3 E-Vents on the roof and 6 Eave Vents in the eaves Re: Roof ventilation 3Mar 07, 2024 8:39 pm Althom E-Vent Roof Ventilation - The Best Whirlybird | Get A Quote (cmiwa.com.au) No moving parts, sits on the roof ridge. Still needs eave vents. We have 3 E-Vents on the roof and 6 Eave Vents in the eaves Thank you Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 8037 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5860 In my experience roof is essential element of the building envelope and hence a common property and should be covered by owners corporation however a detailed review of… 3 6362 |
