Browse Forums General Discussion Re: Facade Render cracks 9Jan 15, 2024 9:46 pm Don’t know how JH board going to work for you Going to have vertical joints, maybe exposed jointing caulked, screws patched and paint With your house, balcony movement, they build on top of the beams and the follows poor workmanship Would need to grind off render or break it all open, generally, framing is poor, coil guns used, render cheap bags, stick on mesh and not embed in render Can be repaired Re: Facade Render cracks 10Jan 18, 2024 10:02 am alexp79 This is most probably the reason After further questioning the builder, I was told that there is an EPS foam on top of the board and he told me the render has a mesh. I am not satisfied with his answear and the cracks are getting wider. Re: Facade Render cracks 11Jan 18, 2024 10:24 am The mesh is often stuck on wall first then rendered over, which means it does nothing Not to specifications Get a scope of works in writing before start, needs to be opened up How will attach JH sheet to foam, getting you on merry go round Do you have a scope of works? If have texture on wall now, the patch will show through The standard for repair of texture is to patch, re-texture corner to corner,… 5 7307 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17882 |
