Browse Forums General Discussion Re: How should l remove rust from steel i beams 4Jan 08, 2024 6:01 am https://www.duluxprotectivecoatings.com ... al-web.pdf https://www.duluxprotectivecoatings.com ... ration.pdf read these two technical documents, you can damage the steel with a wire brush. The first document tells you about the expected life in various corrosive environments, these products are expensive and some require special application equipment, go to a Dulux professional supplier and get some advice. You can also hire a mobile sandblaster. Re: How should l remove rust from steel i beams 5Jan 08, 2024 4:47 pm Pulse https://www.duluxprotectivecoatings.com.au/media/2111/dpcsaubr001-as2312-brochure-final-web.pdf https://www.duluxprotectivecoatings.com ... ration.pdf read these two technical documents, you can damage the steel with a wire brush. The first document tells you about the expected life in various corrosive environments, these products are expensive and some require special application equipment, go to a Dulux professional supplier and get some advice. You can also hire a mobile sandblaster if l cannot get a sandblaster would a sander with sandpaper be better then a wire brush. My plan is to sand the metal beams and then apply White knight rust converter to kill of the remaining rust and then paint it over with a Dulux rust guard primer and lastly a glavanized topcoat. Does that seem the right way to do it thanks, yes they are dry , thats a good idea with fish oil as sanding will be hard 4 3355 THanks , l got a licensed building inspector to look at the rust, he said its just surface rust and it would take many years to become a problem because the beams are so… 22 28771 That just protects from further rust, l want first to apply a rust converter or rust killer to kill the rust thats there, whats the best one for galvanized steel 2 8160 |
