Browse Forums Building A New House Re: Paving Concrete Over Termguard Pipes 2Dec 21, 2023 8:20 pm Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Paving Concrete Over Termguard Pipes 3Dec 22, 2023 8:02 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Paving Concrete Over Termguard Pipes 10Dec 25, 2023 4:31 pm eguan88 Althom The Termguard website has detailed installation instructions with specific requirements for piping under concrete. What you've got there does not in any way comply and you shouldn't be paying for it until rectified. is it usually installed by the builder or Termguard? It can be installed by a number of licenced pest control companies. I would doubt that any builder is approved to do installation and that they would be required to get someone in who knows what they are doing Re: Paving Concrete Over Termguard Pipes 11Dec 26, 2023 10:42 pm As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide that leaches into the soil/sand about 300mm down and 300mm out which creates a kill zone. Dig the pipe down into a trench and fill the trench with sand/soil, then form up and concrete over. Or have a termite guy cap it to the left of the garage and the right of the entry porch. The concrete you will be pouring for the drive/porch will have abelflex between the two concretes (slab / drive), your slab looks to be about 385mm so you are probably on a H1 or H2 site. The abelflex has a tear-away to the top to produce a sealant well to the top section of the slab, your termite guy can apply a termite silicon to create a termite barrier and a moisture barrier preventing moisture wicking down between the two slabs. You achieve a termite barrier, a moisture barrier, and a visual barrier all in one go. We are Expert Consultant's, and we are here to help. Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6476 Just get as close as you can without hitting the posts. Once you are close to the edge of the path the chance of cracking is minimised. 7 9326 4 5319 |
