Browse Forums Outdoor Living Re: Deck joist, bearer and posts 8Sep 25, 2023 3:03 pm So, I'll be going with a 120x45mm joist. That'll sit on a double 120x45mm bearer at 1400mm using 4 stirrups. If I find that space under the bearer is too tight, I could still use double 90x45mm for the bearer. To get my 5000mm length, the joists will only need to hang over the bearer by 360mm. A continuous span of F5 falls well within my requirements for both span and cantilever. I'd probably first dig the 4 holes for the stirrups, fix a few of the joists, hang the bearer off the joists, then hang the stirrups off the bearer. Then all I need is to fill the hole with concrete and all should be well. Re: Deck joist, bearer and posts 9Sep 26, 2023 8:23 am Pulse https://www.bunnings.com.au/deko-250-x-150-x-150mm-instant-concrete-foundation-block_p1080391?store=7212&gbraid=0AAAAADtbEB_ffw32ZgyF5i0I-Bdmma65M&gclid=EAIaIQobChMIzJ2q-Me2gQMVF6RmAh0IownIEAQYASABEgIV-vD_BwE&gclsrc=aw.ds good option? Seconded; we just used these last weekend to build a small deck. They worked perfectly as we have bluestone in the area where we wanted to build so digging down was not really an option! -= Are you still using a notebook or spreadsheet to keep track of your customers and appointments? You need Simple Time Planner - Free Appointment Software =- Hi Mrboh Just wondering if you have any BAL or flame zone issues on your block, as getting compliance with BAL requirements whilst doing bearers and joists is tough. Not… 1 8643 Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me. There maybe should be an additional J1 between TB10 and T12 if… 3 32294 1 10349 |
