Browse Forums General Discussion Re: Double Brick Wall Cavity Insulation - Builder Wrong Prod 2Apr 21, 2023 9:11 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Double Brick Wall Cavity Insulation - Builder Wrong Prod 5Apr 23, 2023 12:22 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Double Brick Wall Cavity Insulation - Builder Wrong Prod 7Apr 25, 2023 1:05 pm It is usually a very bad idea to put EPS in front of batts insulation. EPS has low vapour permeability, while mineral wool and gyprock have high vapour permeability. This means that excessive moisture will be trapped in between and will impact not only the insulation performance levels, but potentially will be promoting mould behind your gyprock and can even eventually impact the structural stability of the framing (in the long run). Also, depending on your location, mass enhanced R value for your double brick design, shown above, will be in R3.3-4.1 range, which is more than enough for the absolute majority of the Australian climate zones. Re: Double Brick Wall Cavity Insulation - Builder Wrong Prod 8Apr 29, 2023 9:56 am So prior to designing our place I invested quite a bit of time in research on all components of our build. I looked at the temperature range for our climate ( temperate and 1.4 km from the coast ) the expected comfortable temperature inside the house - summer and winter, the type of insulation, building methods as per my drawings above, dew point etc and have concluded that we should be fine. We never have frosts and it rarely dips below 8ºC in winter. All rooms have opening windows over the minimum recommended for ventilation. If we lived in a colder climate then yes I may alter how we insulated the house but I'm pretty happy that for most of our walls we will achieve an R-rating of around 4.5. Also I don't know where you get that R rating range for that wall above? A standard double brick cavity wall only has R 0.69. Adding 40mm or 50mm EPS or similar adds another 1.8 only for a total of 2.18. Making it a still air gap adds another 0.68 of course. Stewie Re: Double Brick Wall Cavity Insulation - Builder Wrong Prod 9Apr 29, 2023 1:12 pm Hi Stewie, I am talking about moisture trapped from shower/bathroom and from cooking mainly. This has to be very well mechanically ventilated every time, plus the effect of accumulation is rather long term. As for R values, I am talking about mass enhanced R values - double brick is a high density wall and has thermal mass effect, this is why you can't use standard way of calculating thermal efficiency. For the detailed explaination, pls take look at this article here, it is written mainly for the precast concrete, but the idea is exactly the same: https://www.nationalprecast.com.au/wp-c ... ator11.pdf Re: Double Brick Wall Cavity Insulation - Builder Wrong Prod 10Apr 30, 2023 7:26 pm Well, all bathrooms/ensuites and the kitchen will all obviously have some sort of mechanical ventilation. You'd have to be an idiot not to. In all my years of building and doing lots of renos, additions and new houses I couldn't name any that we did where those rooms weren't ventilated.All the other rooms will have opening windows and doors as well. I'm not really worried about the thermal mass effect either. Our design and those walls as above will be more than enough to cope with temperature fluctuations given our particular temperate climate and minimal energy needs. The thermal assessor for our NatHERS certificate rated our house at 6 stars so that will do me. Stewie Re: Double Brick Wall Cavity Insulation - Builder Wrong Prod 11Apr 30, 2023 11:56 pm I am saying that double brick has similar thermal performance (or may be just slightly worse) due to thermal mass effect. It will be still very interesting to see the state of your framing after 10-15 years, considering the above mentioned construction. May be it will be fine, but I am still worried that even small doses of trapped vapour might eventually cause issues in the longer term. Rotten frames is something they dealt a lot with at the UK where they have used to put in a OSB board (also very low vapour permeability) in front of mineral wool insulation and even though they generally use vapour barrier on the internal side of the wall it was oftentimes damaged/punctured. BTW I hope that your wall sarking is vapour permeable though. As for NatHEARS, 6 stars is everyone getting these days, now 7 stars will be mandatory from September. But frankly, I wouldn't generally trust NatHERS calculations as they usually take 'perfect' conditions into consideration, e.g. not considering moisture inside the walls, thermal bridging etc. there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18644 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16686 Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5870 |
