Browse Forums Heating, Cooling & Insulation Re: No Air Gap for Sisalation Paper 3Feb 17, 2023 3:58 pm I was told the air gap needs to be between the foil side (inside) and everything else. The paper has been installed between the exterior wall and the wall frame (not really leaving much of a gap there) Re: No Air Gap for Sisalation Paper 5Sep 29, 2023 3:15 am IncredibleBulk Hey all I'm trying to figure out the best way to insulate the walls in a home office I had recently built. The installers included sisalation under the external walls, with the instruction "make sure you leave air between it and anything else" The wall studs are 7cm deep. The narrowest insulation batts I've been able to find are 7.5cm and have been told "it's fine if it's compress it a little, they're never really the full depth anyway" However doing this would leave no air gap between the paper and the batt. Which leaves three options - ignore the gap and just do it. Reducing both the reflective property of the paper and risking heat condution - cut the insulation battts in half. Messy and difficult to keep even thickness through the length - find a thinner insulation batt? Any suggestions Use 50mm rockwool fibre insulation if it concerns you that much. Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 5057 This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well… 13 20314 2 8339 |
