Browse Forums General Discussion 1 Feb 15, 2023 5:39 pm Hi All So, I want to hang a bed from my loungeroom ceiling. Assuming the bed is constructed appropriately and I am hanging it from each corner using chain or thick rope, I need to understand how and where I need to attach it to in the ceiling for maximum strength and safety. Thank you in advance! 🫐 Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Hanging Bed - Help! 2Feb 15, 2023 8:46 pm If I was to do this I would add extra supports in the ceiling cavity that are independent of any ceiling joists or truss bottom chords. The extra load of the bed wouldn't break anything, but you would crack your plasterboard with the extra deflection from the weight. It's been a while but I think a ceiling member is designed to carry 15kg/m2 with a 3 mm deflection. Could be way off though it's a little fuzzy up there. thanks chippy! here is the back of the wall which has not been backfilled yet. Here is the same back of the wall taken from the other end, behind the steps. As you… 5 1852 brokers will also be in a position to get you a better rate than the advertised rate most times. 6 7943 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 13361 |
