Browse Forums Building A New House Re: Cost of windows vs brick + gyprock + batts etc 2Jan 23, 2023 4:06 am Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Cost of windows vs brick + gyprock + batts etc 3Jan 23, 2023 8:48 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Cost of windows vs brick + gyprock + batts etc 7Jan 23, 2023 3:57 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Cost of windows vs brick + gyprock + batts etc 12Jan 26, 2023 12:37 pm buildnoob Great info stonesthrow. Super handy to know. Out of curiosity how do those fancy houses that grace the covers of architectural digest stay energy efficient? They’re all glass top to bottom every wall. They are not really energy efficient even if they are triple glazed Re: Cost of windows vs brick + gyprock + batts etc 15Jan 26, 2023 5:43 pm buildnoob How do they pass basix or nathers? It's a great question. NatHERS is imperfect like any model and I think can be worked around. Having gone through a design of my own with an energy assessor, some things do boost the rating that are questionable and you can also say you're going to build certain things and not actually do it in practice. I doubt many houses perform to their star rating. Either way, it's a fact that windows are weak points and you should carefully consider sizing and location. Re: Cost of windows vs brick + gyprock + batts etc 16Jan 26, 2023 7:04 pm Great advice, thanks stonesthrow and alexp79. My front facade will face west, so for aesthetic reasons I’ll be putting in a few windows. My other windows are north and east and I only have a couple facing south (garage and bath). To make this energy and cost efficient, I plan to low e only the west windows. The big windows and doors will face east where the kitchen and living face the backyard. Bedrooms face north. Are there any improvements I can make from basix perspective? I’m in suburban Sydney so winters aren’t too cold and summers not overly hot, so dont really see the need for double glazing. I’ll probably upgrade the ceiling and external wall insulation. Re: Cost of windows vs brick + gyprock + batts etc 17Jan 26, 2023 7:14 pm buildnoob Great advice, thanks stonesthrow and alexp79. My front facade will face west, so for aesthetic reasons I’ll be putting in a few windows. My other windows are north and east and I only have a couple facing south (garage and bath). To make this energy and cost efficient, I plan to low e only the west windows. The big windows and doors will face east where the kitchen and living face the backyard. Bedrooms face north. Are there any improvements I can make from basix perspective? I’m in suburban Sydney so winters aren’t too cold and summers not overly hot, so dont really see the need for double glazing. I’ll probably upgrade the ceiling and external wall insulation. Yeah I don't think you need to worry much about getting too much sun in winter given you're in Sydney. I think it's still preferable though. I would worry about the east and west facing windows though. Low e won't do much when the sun is low and coming straight through. My advice would be to engage an energy assessor during the concept stage (before you're locked into a design). See how it performs and seek advice on best bang for buck changes to take back to the builder /architect. Re: Cost of windows vs brick + gyprock + batts etc 18Jan 27, 2023 10:30 am buildnoob Interesting Ecoeco! So commercial windows are gimmicky and better to go with residential + low e, glazing or custom sized to suit. Yes, that's it. So called commercial are very low tech, wide and thick. Most residential windows will out perform commercial energywise, and the residential windows will be designed and tested to do what they do best. I am not a fan of Low-e because it only stops radiant heat, i.e. sunlight. It's a filter for solar heat. Yes it registers on the various softwares, but really, it only affects solar heat gain. Any form of shade preventing direct sunlight will outperform Low-e. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Cost of windows vs brick + gyprock + batts etc 20Jan 27, 2023 4:07 pm ECOECO buildnoob Interesting Ecoeco! So commercial windows are gimmicky and better to go with residential + low e, glazing or custom sized to suit. Yes, that's it. So called commercial are very low tech, wide and thick. Most residential windows will out perform commercial energywise, and the residential windows will be designed and tested to do what they do best. I am not a fan of Low-e because it only stops radiant heat, i.e. sunlight. It's a filter for solar heat. Yes it registers on the various softwares, but really, it only affects solar heat gain. Any form of shade preventing direct sunlight will outperform Low-e. Really noob question - "because it only stops radiant heat" - so what doesn't low e stop? Like heat and noise loss? Found the answer. The recommended distance is .... 1 11057 DIY, Home Maintenance & Repair We have just moved our gym into a new industrial unit. We have had the walls painted around two weeks ago. Overnight, this white residue has come up on a number of the… 0 4227 Get an independent building inspection done now. Once handover is done, if they didn't fix it beforehand its doubtful they ever will. Get someone independent from them,… 17 21919 |
