Browse Forums Building A New House Re: Adding eaves to facade = shorter external walls ? 9May 11, 2022 8:01 pm Bumping an 11 year old thread... We are building and have optioned 450mm eaves and a 25 degree roof pitch. We have 2.7m internal ceilings. The end result is that there are no bricks above the windows, and the portico has less of a timber infill. This to me looks a bit worse. I would have thought they could just leave the eaves at a certain height and then increase the roof pitch from there. Is this not possible? If I have to go the builders way, should I be getting a discount for the fact there are less bricks and no lintels above the windows? Or will they install this anyway and cover it with the eaves? Appreciate any advice! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Adding eaves to facade = shorter external walls ? 10May 12, 2022 7:13 pm You should be able to specify to have the eaves finish at the same height as your internal ceiling (2.7m). This will increase the roof height if leaving the pitch the same and cost more for materials. 5 4885 Adding pool to KDR Build. During or after building plan approval Hi, we are doing a KDR on a downhill sloping block. Adding a pool increases the non-permeable area,… 0 75858 Hi Everyone, I'm looking to implement this design, but does anyone know how the drainage would work for the plants on the second floor? I don't want down pipes at the… 0 120829 |
