Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 903Feb 16, 2022 7:24 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 904Feb 16, 2022 7:37 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 908Mar 22, 2022 12:46 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 911Apr 22, 2022 7:15 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 913Apr 23, 2022 11:16 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 915Apr 24, 2022 11:38 am Michelle ren_ho What would you recommend for a pet friendly timber or engineered timber floor? To minimise scratches, and if scratched occur, have them be less visible. We're thinking a light colour wood, but should we be trying to get the hardest wood we can afford or do they not make much of a difference? We will have tiles in the main thoroughfares. Good morning, Oaks are the way to go if you are concerned about scratching of timber floors. They hide the scratches much better than an Australian timber. Don't do a dark floor, they show everything. Good morning Michelle, Did you have any thoughts/feedback on the Eucalyptus Steps by Imagine / Airstep? Re: I work in flooring - do you have a flooring question? 916Apr 27, 2022 2:32 pm Hi Michelle, We have been looking more intently now - I've been pleasantly surprised about pricing so far. Mostly we have looked at the hybrid (with interlock, 0.5mm wear later and built in underlay) but have seen a few luxury vinyl planks (to glue down). Audacity have both and some info we found interesting: https://www.flooringxtra.com.au/wp-cont ... ure_FA.pdf My impression is that the LVP's are solid vinyl? So that means no wear layer? In the spec sheet they have acoustic properties with the hybrid quieter - maybe due to the underlay? Do you find there is a difference in the type of sound it makes? Sounds like a silly question I know.. The pricing seems good. For the Audacity it was $85/sm installed for HRC, and $69/sm for the LVP installed. We gave them our plans for a preliminary quote (for https://www.flooringxtra.com.au/product ... otted-gum/) and it came back at $70/sm installed (inc 5% wastage). Does that seem too good to be true? Do I need to be wary of these products? Re: I work in flooring - do you have a flooring question? 917Apr 27, 2022 7:54 pm Budapest Hi Michelle, We have been looking more intently now - I've been pleasantly surprised about pricing so far. Mostly we have looked at the hybrid (with interlock, 0.5mm wear later and built in underlay) but have seen a few luxury vinyl planks (to glue down). Audacity have both and some info we found interesting: https://www.flooringxtra.com.au/wp-cont ... ure_FA.pdf My impression is that the LVP's are solid vinyl? So that means no wear layer? Every hard floor has a wear layer. In the spec sheet they have acoustic properties with the hybrid quieter - maybe due to the underlay? Do you find there is a difference in the type of sound it makes? Sounds like a silly question I know.. Both quiet, just laid defiantly The pricing seems good. For the Audacity it was $85/sm installed for HRC, and $69/sm for the LVP installed. We gave them our plans for a preliminary quote (for https://www.flooringxtra.com.au/product ... otted-gum/) and it came back at $70/sm installed (inc 5% wastage). Does that seem too good to be true? Do I need to be wary of these products? I have no idea about Flooringextra, I work at Choices Flooring, we don't get involved with each other. (friendly with each other but keep our work to our own stores. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 918Apr 27, 2022 8:01 pm Check out my new 2mm vinyl plank from Karndean recently installed in my laundry! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 919May 10, 2022 11:41 am Hi Sorry to be late in on this, we have existing Kardean floorboards and we are about to start some renos and was wondering if anyone knew the best way to remove the glue from the back and then store the planks so we may re-use most of them?? Re: I work in flooring - do you have a flooring question? 920May 12, 2022 6:24 pm dmm12 Hi Sorry to be late in on this, we have existing Kardean floorboards and we are about to start some renos and was wondering if anyone knew the best way to remove the glue from the back and then store the planks so we may re-use most of them?? All I know is, we use a heat gun to soften the glue and lift the planks. I guess once you get them up you could try a scraper. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 41458 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 11177 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 5062 |
