Browse Forums Building A New House Re: Starting Over - Custom Build 2Apr 17, 2021 6:40 pm Simeon McGovern Affordable Custom Homes, We design and build to your budget Ashington Homes www.ashingtonhomes.com.au Re: Starting Over - Custom Build 4Jun 01, 2021 3:04 pm Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Starting Over - Custom Build - Plans 3.0 12Oct 15, 2021 3:12 pm Bit of an update. We ended up engaging with another custom builder and I pretty much reworked 95% of my design. The house now has 2 smaller splits downstairs and a traditional staircase to the upper level. Family situation has also changed so needed to accommodate an oversized Guest Bed / 2nd Master on the entry level. Managed to get 2590mm height ceilings upstairs and we are really happy about the 4.3 for the lower Kitchen / Dining / Living areas. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Custom Build - New Plans added - check them out! 14Oct 15, 2021 5:34 pm It's brick veneer where the bricks sit on lower level brick and weather board clad frame elsewhere. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Custom Build - New Plans added - check them out! 15Oct 15, 2021 6:00 pm chippy It's brick veneer where the bricks sit on lower level brick and weather board clad frame elsewhere. Correct, the cladding is represented by the thinner wall line on the upper level. Re: Custom Build - New Plans added - check them out! 17Oct 18, 2021 12:57 pm Blonde Looks great, what a good block size. Cheers thanks. We had been planning this for a while and looking for the right property at the same time. This opportunity presented itself so we jumped on it. Re: Custom Build - New Plans added - check them out! 18Jan 20, 2022 3:27 pm After a number of changes back and forth with the builder and now after a break over Christmas / New Year, the Tender Presentation is locked in for Monday 24/1/2022. With the sloping site and the presence of rock, we are little anxious to learn the sites costs component as this may affect other parts of the build in terms of fit and finish. We did receive a heads up from the builder that we are less than $10K over our budgeted number. Will know for sure on Monday. Re: Custom Build - Tender Presentation 24th Jan 19Jan 21, 2022 11:32 am Hi there KnockItDown Your whole journey was fascinating to read. What an adventure! How did you go about preparing the tender for builders? Did an estimator do a BOQ estimate for you? I have been blogging about custom home building. The information might prove useful to you at the moment. Here is a link to an ultimate guide to custom home building Here are 9 best contract negotiation tactics In the coming weeks, I will write more about the whole process, but if you have any questions, I am happy to help! Regards, Colin Operations Director Homebuildguide.com.au Click Here For A Free eBook About Custom Home Building Re: Custom Build - Tender Presentation 24th Jan 20Jan 21, 2022 4:16 pm Hi Colin, I did the original designs of the house which I drew myself based on what we wanted. I then approached a number of builders to see if they could build to my design. As expected, a number of builders weren't interested due to the slope (2.5 metre fall over the build envelope). I started along the initial sketch / site layout process with 2 builders and then settled on the one that could meet our needs and could also build what we wanted to the budget we had. That builder is presenting their formal tender to us on Monday. All things going well we will progress from there. Tradie may sit at home but will need to get house plastered as well or will you sit it out? 6 10551 I engaged my builder in December last year and we’ve been working on preliminary drawings for last couple of months. I got a call from the salesperson this morning… 0 1881 For our new build in NSW we opted for a heat pump with a 315L storage tank. Early days yet as we only moved in 6 weeks ago. Haven't run out out of hot water though. Ours… 7 4600 |
