Browse Forums General Discussion Re: Query related to Site cut 3Sep 13, 2021 12:22 pm That means your site will be cut by almost 70 cm plus the depth of your slab (add another 10 cm) and, if you are doing waffle slab, the height of your waffles - add in another 35 cm. So altogether, closer to 115-120 cm. Multiply by the size of your building envelope to understand the amount of volume to be removed. For your site, I would rather suggest to go with the rafted slab instead. Re: Query related to Site cut 4Sep 13, 2021 12:37 pm alexp79 That means your site will be cut by almost 70 cm plus the depth of your slab (add another 10 cm) and, if you are doing waffle slab, the height of your waffles - add in another 35 cm. So altogether, closer to 115-120 cm. Multiply by the size of your building envelope to understand the amount of volume to be removed. For your site, I would rather suggest to go with the rafted slab instead. Think you missed the point. He's a student looking for answers on how to complete his homework Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Query related to Site cut 5Sep 13, 2021 12:48 pm Noname alexp79 That means your site will be cut by almost 70 cm plus the depth of your slab (add another 10 cm) and, if you are doing waffle slab, the height of your waffles - add in another 35 cm. So altogether, closer to 115-120 cm. Multiply by the size of your building envelope to understand the amount of volume to be removed. For your site, I would rather suggest to go with the rafted slab instead. Think you missed the point. He's a student looking for answers on how to complete his homework HI Noname, Just to correct you its not part of my assessment. its part of my lecture which i couldn't understand and surely contacted my instructed as well. While searching regarding that on google, I found this forum and thought to discuss with the people working in that. Hope you dont mind that. Re: Query related to Site cut 6Sep 13, 2021 12:52 pm Ad.Farooq Noname alexp79 That means your site will be cut by almost 70 cm plus the depth of your slab (add another 10 cm) and, if you are doing waffle slab, the height of your waffles - add in another 35 cm. So altogether, closer to 115-120 cm. Multiply by the size of your building envelope to understand the amount of volume to be removed. For your site, I would rather suggest to go with the rafted slab instead. Think you missed the point. He's a student looking for answers on how to complete his homework HI Noname, Just to correct you its not part of my assessment. its part of my lecture which i couldn't understand and surely contacted my instructed as well. While searching regarding that on google, I found this forum and thought to discuss with the people working in that. Hope you dont mind that. My point still stands. The answer you got was from somone who assumed you were building not clarifying school work. Dark matter scientist, can breathe underwater, mind reader and can freeze matter just by willing it. Trust me, its in my sig. Re: Query related to Site cut 7Sep 13, 2021 12:53 pm alexp79 That means your site will be cut by almost 70 cm plus the depth of your slab (add another 10 cm) and, if you are doing waffle slab, the height of your waffles - add in another 35 cm. So altogether, closer to 115-120 cm. Multiply by the size of your building envelope to understand the amount of volume to be removed. For your site, I would rather suggest to go with the rafted slab instead. HI Alexp79, How you calculated 70cm site cut? also the cut will be for the complete site? Re: Query related to Site cut 8Sep 13, 2021 12:55 pm Noname Ad.Farooq Noname Think you missed the point. He's a student looking for answers on how to complete his homework HI Noname, Just to correct you its not part of my assessment. its part of my lecture which i couldn't understand and surely contacted my instructed as well. While searching regarding that on google, I found this forum and thought to discuss with the people working in that. Hope you dont mind that. My point still stands. The answer you got was from somone who assumed you were building not clarifying school work. Good on you. For me its clarifying the concept and I mentioned in the question i am student and wants to classify the concepts which i couldn't in the online class. Thanks for your help. Re: Query related to Site cut 9Sep 13, 2021 1:00 pm Ad.Farooq alexp79 That means your site will be cut by almost 70 cm plus the depth of your slab (add another 10 cm) and, if you are doing waffle slab, the height of your waffles - add in another 35 cm. So altogether, closer to 115-120 cm. Multiply by the size of your building envelope to understand the amount of volume to be removed. For your site, I would rather suggest to go with the rafted slab instead. HI Alexp79, How you calculated 70cm site cut? also the cut will be for the complete site? I haven't seen your picture (it was not posted), so can't tell wether your current levels are consistent across the site. 70 cm is the difference between 604.25 and 603.56 (69 to be precise) Re: Query related to Site cut 10Sep 13, 2021 7:42 pm Hi Alex i have added in the dropbox link https://www.dropbox.com/s/zhgss8v8dyw2j ... 0.png?dl=0 let me know if you see that or you need more information Re: Query related to Site cut 11Sep 14, 2021 1:25 pm Ad.Farooq Hi Alex i have added in the dropbox link https://www.dropbox.com/s/zhgss8v8dyw2j ... 0.png?dl=0 let me know if you see that or you need more information Hi Alexp79, are you able to access the photo? Adnan Re: Query related to Site cut 12Sep 14, 2021 1:31 pm Ad.Farooq Ad.Farooq Hi Alex i have added in the dropbox link https://www.dropbox.com/s/zhgss8v8dyw2j ... 0.png?dl=0 let me know if you see that or you need more information Hi Alexp79, are you able to access the photo? Adnan Yes, so if level is consistent, then my calcs stay the same Re: Query related to Site cut 13Sep 14, 2021 2:01 pm alexp79 Ad.Farooq Ad.Farooq Hi Alex i have added in the dropbox link https://www.dropbox.com/s/zhgss8v8dyw2j ... 0.png?dl=0 let me know if you see that or you need more information Hi Alexp79, are you able to access the photo? Adnan Yes, so if level is consistent, then my calcs stay the same So, we have to cut complete site of 690mm? Adnan 2 7438 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10864 There is no reason why building contract reconciliation cannot be done prior to handover, if the builder won't do it get someone to do it for you. Why would you pay for… 3 7103 |
