Browse Forums Renovation + Home Improvement Re: Exhaust fan noisy - squeaking and flapping noise 3Jun 10, 2021 1:35 pm It's probably an expensive solution but you could look at one of these. https://www.schweigen.com.au/catalogue/brw600 The motor unit is installed on the outside of the house which would mean with a back draft stopper there would be nothing inside the house except the tubing so wind shouldn't make a difference. Re: Exhaust fan noisy - squeaking and flapping noise 4Jun 10, 2021 2:19 pm arcadelt The backdraft shutter is probably what is making the flapping noises in windy weather. Only way to fix it is to have one that doesn’t flap. Only way I have surmised to make that work is to install a manually or electrically activated one. Do you have an example of this sort of exhaust fan which has an electrically activated backdraft shutter? My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5574 Hi, I have a double and whenever the wind picks up I can hear alot of banging in certain areas of the house. I've had a look round and can't see any obvious issue but… 0 10858 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 14876 |
