Browse Forums Windows & Doors 1 May 17, 2021 9:51 am Hello all, Our house is currently being renovated and as part of it we are getting two new aluminium sliding doors installed - one is a large stacking sliding door within an existing house and another one is for a brand new extension where one side of the sliding door abuts the existing external wall. The large stacker door required core filled 200-series blocks on either side to support a double bond beam above. The builder put up the door frames first and then the block layer built around it. I am wondering why was it done this way as I have seen it done like this before? Normally I have seen the blocks laid first and then windows and doors installed. It would not concern me how it is done but now the frames have paint damage in numerous spots and the sliding door tracks covered with mortar and dirt. I am worried how damaged the frames will be by the end and also how all the dirt in the door tracks will impact the door rollers. I understand they will clean them but I doubt they will get all the dirt out. Thanks in advance! Re: Install sliding doors to a blockwork wall 2May 17, 2021 10:23 am Hey bc89 Welcome to the forum Unfortunately, The builder either choose cheap windows that didn't allow for later installation or detailed the incorrect installation, hard to say without photos and engineering drawings Either way, you will be left patching/painting the cracks/scratches. BTW we have no problems installing into double brick walls... in brick veneer I would recommend steel columns and beams Ask for an extension of the maintenance/structural period. hth Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs We are looking for sliding doors which are 5 metres tall. There are a few European options. Any manufacturers in Australia or distributors? 0 5310 Pls help! The black marks show where our outdoor entertaining area would be along side of house as we have an irregular backyard and want to make use of the side as… 0 4528 That's a fantastic result! Happy you got it sorted out. cheers Simeon 6 8954 |
