Browse Forums General Discussion 1 Mar 22, 2021 4:33 pm I am living in a newly built house which was built in 2017. My garage has a hole and it is leaking. I searched a bit, and it could be part of weep holes. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ the red thing under the beige brick is flashing, which looks like the below image. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ So now, I cannot understand why this hole has opened in my garage. When we have heavy rain outside, the hole leaks water all the time. The amount of water is more then 40L. I think, this hole should not exist in the garage, is that correct ? And to fix this problem who should i call ? The builder doesn't have any idea why it is leaking, The builder even called a plumber to find out the reason, but the plumber was really puzzled why we even called him in the first place. Can you please help us. Thank you in advance. DIY, Home Maintenance & Repair could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the… 1 1823 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 11184 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 5062 |
