Browse Forums Building A New House Re: Home networking future proofing 5Aug 17, 2020 3:27 pm Follow my build here: https://www.instagram.com/ivy5custom Re: Home networking future proofing 7Aug 17, 2020 8:15 pm Follow my build here: https://www.instagram.com/ivy5custom Re: Home networking future proofing 12Aug 23, 2020 9:46 am chennaiite Especially a TV. No matter how best your router is, WiFi has inherent limitations and is best for lighter applications such as mobile devices. Not really. If you wire most TVs you will get worse performance than if you had a good 5Ghz WiFi network connection. Most models, particularly LG TV's, only have a 100Mbit NIC. So 5Ghz WiFi is far better. Just chuck it on a dedicated 5Ghz WiFi network if possible. If you're hardwiring you'd be better with a set top box like an Apple TV, Nvidia Shield. Re: Home networking future proofing 13Aug 23, 2020 9:58 am dga chennaiite Especially a TV. No matter how best your router is, WiFi has inherent limitations and is best for lighter applications such as mobile devices. Not really. If you wire most TVs you will get worse performance than if you had a good 5Ghz WiFi network connection. Most models, particularly LG TV's, only have a 100Mbit NIC. So 5Ghz WiFi is far better. Just chuck it on a dedicated 5Ghz WiFi network if possible. If you're hardwiring you'd be better with a set top box like an Apple TV, Nvidia Shield. Sorry I wasn't clear enough. The reason to wire devices where you can is to keep as less devices connected to WiFi as possible. The impact on wifi performance when 4 devices are connected VS say 15 devices connected simultaneously is well documented. Then there's latency and interference from other appliances (microwaves and such). Although it's true there are some commercial grade routers out there I know of that won't degrade even with 100 simultaneous connections. To your point of 5ghz, I don't think there's any type of content out there that would require more than 100mb of speed. Re: Home networking future proofing 14Aug 23, 2020 10:20 am chennaiite To your point of 5ghz, I don't think there's any type of content out there that would require more than 100mb of speed. That's what the manufacturer says, but my Plex server doesn't listen to them.... there are a number of occasions where the bandwidth required exceeds the amount available when using a wired connection (which results in buffering). That might not be the use case here, but it could well be a consideration. I'm not suggesting cable shouldn't be run to the location (I did it for all mine) and it is used for the Xbox and Fetch TV. Just not the TV because it's not capable enough (due to the inherent limitations of the TV). Re: Home networking future proofing 15Feb 16, 2021 3:39 pm dga chennaiite Especially a TV. No matter how best your router is, WiFi has inherent limitations and is best for lighter applications such as mobile devices. Not really. If you wire most TVs you will get worse performance than if you had a good 5Ghz WiFi network connection. Most models, particularly LG TV's, only have a 100Mbit NIC. So 5Ghz WiFi is far better. Just chuck it on a dedicated 5Ghz WiFi network if possible. If you're hardwiring you'd be better with a set top box like an Apple TV, Nvidia Shield. This is my current setup now after a network refresh due to COVID work from home arrangements. Upgraded to UniFi Dream Machine Pro, 16 port USW PoE switch, 2 x 8 Port UniFi Poe switches, FlexHD and a UniFi AC Lite access point upstairs. We’re only a family of four but with around 45 devices connected at one time on average we needed a bit of bandwidth. All of the above with only two data points in the house from the NBN handoff. It’s hard to future proof anything, but you can always come up with a solution based on your needs. Re: Home networking future proofing 19Feb 19, 2022 7:57 am dga chennaiite Especially a TV. No matter how best your router is, WiFi has inherent limitations and is best for lighter applications such as mobile devices. Not really. If you wire most TVs you will get worse performance than if you had a good 5Ghz WiFi network connection. Most models, particularly LG TV's, only have a 100Mbit NIC. So 5Ghz WiFi is far better. Just chuck it on a dedicated 5Ghz WiFi network if possible. If you're hardwiring you'd be better with a set top box like an Apple TV, Nvidia Shield. This post makes so much sense. I have all my Tv's CAT 6 wired ( have 7, including LG, Samsung and Hisense) but have been haveing problems with my 2 Lg's and the high speed we get with the NBN. We often clock 200-300 mbs I got a Mesh Wifi for christmas and it has been amazing at solving the issues. Dont know why buy your post helped me Thanks Simeon Architectural Homes & Duplexes - specialising in custom designing homes to your budget Get a Free Onsite Consultation Today or send a PM for information, questions or advice. Re: Home networking future proofing 20Feb 19, 2022 12:27 pm Ashington Homes dga chennaiite Especially a TV. No matter how best your router is, WiFi has inherent limitations and is best for lighter applications such as mobile devices. Not really. If you wire most TVs you will get worse performance than if you had a good 5Ghz WiFi network connection. Most models, particularly LG TV's, only have a 100Mbit NIC. So 5Ghz WiFi is far better. Just chuck it on a dedicated 5Ghz WiFi network if possible. If you're hardwiring you'd be better with a set top box like an Apple TV, Nvidia Shield. This post makes so much sense. I have all my Tv's CAT 6 wired ( have 7, including LG, Samsung and Hisense) but have been haveing problems with my 2 Lg's and the high speed we get with the NBN. We often clock 200-300 mbs I got a Mesh Wifi for christmas and it has been amazing at solving the issues. Dont know why buy your post helped me Thanks Simeon It's not great advice. Nothing you're going to be streaming on a tv requires more than a 100mbit connection, 25mbit is reccomended for 4k 30hz. The few things that might exceed those, 4k 144hz+ game streaming such as on a Nvidia Shield will by far benefit more from the reduction in latency from going wired than the extra overhead. You also run into saturation issues, the more things you put on Wi-Fi, the more congested the spectrum gets and the worse everything performs, stuff that doesn't need to be on the Wi-Fi shouldnt be on it. Eg don't stick tv's and fridges etc on Wi-Fi as you'll just end up with worse performance on phones, tablets and laptops. The point about Apple TV etc is good advice though, devices like the Nvidia Shield, Roku etc are far better than the crap software on most tv's. I've added cat 6 to all of my tv points, but it will be to run off Nividia Shields, especially given tv's are all starting to push ads in their ecosystems now. Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 21099 Brass fly wire, you will need to cut it, shape it and jam it into brick slots 1 7981 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 17142 |
