Browse Forums Building A New House Re: Building a Doulton in Geelong 39Jul 27, 2020 3:39 pm Sparkyf They didn't give me the exact reason, other than this in an email. I researched numerous products, and found similar house design facades with hebel, James said I would have to ask the other builder about that! The mode does have numerous vertical and horizontal planes, so I guess there would be a lot of weight with 75mm concrete panels on the wooden frame that was designed for lightweight EPS! James' reply: With the other job we had on site, we switched back from Hebel to EPS. The framing and engineering wasn’t designed to suit Hebel’s weight/thickness/fixing requirements. Once the customer saw what the Exsulite looked like (ie exactly the same as rendered Hebel) they were happy to go back to the EPS, and that job is now steaming along onsite. Thank you for sharing your journey with Metricon. Interesting on they can't do Hebel in the front, even ask for placing more steels to increase the weight holding is not possible? Re: Building a Doulton in Geelong 40Jul 28, 2020 4:36 am They have a client building one in Ballarat, and they wanted hebel all around also, but they were having a lot of problems with the hebel on the front (probably due to the complex shape of the projections), so they ended up doing EPS at the front and hebel around the (straight and easier) back and sides. It's all rendered anyway, so will look the same, you just cant bolt anything to EPS (i.e. Christmas lights we were planning)! You can get an idea from this image I compiled with front view, and ground and first floor overheads (corresponding front sections highlighted): [img:*****]https://forum.homeone.com.au/u/94542_1595875059.jpg[/img:*****] Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12838 Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11883 |
