Hi everyone
Does anyone know the cost difference between using hebel and the type of brick in this photo?
Thanks
Browse Forums Building A New House Re: Hebel vs Bricks 4May 22, 2020 6:08 pm Should be more or less similar. Hebel panels are $50-60 per sqm supply and installation labor and material costs are around $20-$25 per sqm. Face bricks supply are starting from $1.5 per brick or $80+ per sqm + $60-100 per sqm for bricklaying and mortar (depending on where you are). But Hebel requires acrylic rendering, which adds another $50-60 per sqm + scaffolding related expenses. 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6862 Since you are in the design stage then I would direct your questions, in writing of course, to your designer. Depending on the trust you have in the competence of your… 4 6081 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 15423 |
