Browse Forums DIY, Home Maintenance & Repair Re: Mounting speakers on Wall - no stud 4May 11, 2020 11:53 am If you can pick up a noggin then I'd use that for the top fixing. That way the tension is taken through a solid fixing. Realistically that would be enough to take the full weight of the speaker and bracket. Any screws at the bottom are taking more sheer force and are more for location so even a wall mate would do. Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Mounting speakers on Wall - no stud 5May 11, 2020 12:03 pm killerkev alexp79 If you use 3/8"+ inch metal toggle bolts, you can easily support 20 kg+ at one point with just gyprock only. I have hung a heavy mirror on a wall without a stud just using toggle bolts and it did a great job. The only thing with these speakers that I'm not sure about is the fact that they extend out from the wall by 40cm. Is this type of weight (I think it's called tensile weight when the weight is being pulled away from the wall rather than straight down?) going to have an adverse effect using plasterboard fixings only? thanks You can put two bolts in the bottom of the fixture as they will be having more load. Otherwise, it will be similar. Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 6331 Thank you again Simeon.. I will call my certifier for that. Have a good day 4 6797 can’t tell from the photo, a tie down rod will be 12mm, is it a steel beam? he should be able to work it out 1 5588 |
