Browse Forums General Discussion 1 Apr 25, 2020 9:59 am Hi there, I am just about to build with Metricon but finding the whole process frustrating with all their extra charges. Would you expect an extra charge to have diamond gloss kitchen cabinets? a lot of other builders do not charge for this as its part of the laminar standard range. Re: Metricon 2Apr 25, 2020 1:40 pm This is where they get you, you need to read all the wording of the initial documents, the "builders range" normally will leave out a lot, they then use this as the a way to upgrade you, good luck with the build Re: Metricon 3Apr 25, 2020 7:01 pm If your own concern is about one builder charging extra for certain kitchen cabinets finish while the other is not, then you should probably reconsider the process of building your own house. What matters in the first place is the price per sqm you pay for a high quality build and make sure that your house is built to the standards with due attention to the details. Secondly, the house should be comfortable from various aspects such as thermally (no gaps or leaks in insulation, high quality insulation is used, high quality double glazed windows, sealing of external doors) and from noise attenuation perspective (no squeaky floors, sound batts to certain walls, e.g. Hebel Floors, etc.). The quality of the internal finishes are just secondary as it can always relatively easily replaced with the more expensive ones during your next renovation cycle. I would rather focus on the quality of the master workmanship itself, it is really more important that you invest in high quality shower mixers, bath tubs as those can be harder to replace than kitchen cabinets, floors or tiles. I also strongly suggest "custom" things like usage of electrical conduits throughout for electrical installations, etc. but I really doubt any of the project builders are using them. Just my 2 cents. Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12797 Hello All π We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9705 We donβt live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 19759 |
