They will charge you $40 to add Noggins. With the experience, I have if don't need any support. But you need wiring and switch for the fan. You can do the wiring as well if yours is single storey or the fan provision is on first floor.
Browse Forums Building A New House Re: Who else is building with Eden Brae? 15461Jan 15, 2020 11:15 pm Current State: Slab/Frame/Bricklayer/Lockup/Lining/Stairs/Kitchen/Wet flooring/Painted/PCI/Got the Keys My Thread: Building Windsor 40 with Eden Brae (Caddens) Re: Who else is building with Eden Brae? 15467Jan 22, 2020 12:03 pm We are currently building a Waldorf and wondering where the best place to put the microwave, the display home has the unit in the pantry. Some display homes have the microwave in the Galley, looking for suggestions from others that have built a Waldorf on other practical locations and pictures if you can share. Re: Who else is building with Eden Brae? 15468Jan 24, 2020 8:39 am Wondering if anyone can help find a suitable location for our whirlybird on our Cremorne. We're having solar installed and found out by looking at the roof that the whirlybirds were missed during installation. That's now being rectified, but the back/north facing roof is where a lot of the panels will be placed. So we're looking at an alternative location, maybe on the south facing top roof? Has anyone done or asked this? I'm also wondering if anyone has upgraded from regular whirlybirds to solar powered ones? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who else is building with Eden Brae? 15469Jan 27, 2020 9:27 pm Hi All, Can someone help me to understand why the ground levels is not flat behind the alfresco area in my house? There is around 500mm height difference in the ground level. I have noticed below yellow highlighted area in the plan. Its marked as "Line of Batter to Cut or Fill" in the plan. When I requested EBH SS to make the ground level flat, I was told that "the pad is as is indicated on the plan. This would be a Basix/ certification design requirement". Can someone help me to understand this statement? Can I still request the builder to make the ground level flat? Thanks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Who else is building with Eden Brae? 15470Jan 31, 2020 8:39 am sumur1au We are currently building a Waldorf and wondering where the best place to put the microwave, the display home has the unit in the pantry. Some display homes have the microwave in the Galley, looking for suggestions from others that have built a Waldorf on other practical locations and pictures if you can share. How often do you use it? We never use the microwave, so threw it in the WIP. If you use it alot, put it where its accessible. Cheers Brickface Re: Who else is building with Eden Brae? 15471Jan 31, 2020 4:25 pm Brickface sumur1au We are currently building a Waldorf and wondering where the best place to put the microwave, the display home has the unit in the pantry. Some display homes have the microwave in the Galley, looking for suggestions from others that have built a Waldorf on other practical locations and pictures if you can share. How often do you use it? We never use the microwave, so threw it in the WIP. If you use it alot, put it where its accessible. Thanks, we put it in the Galley. Re: Who else is building with Eden Brae? 15472Feb 18, 2020 12:19 pm sumur1au Apparently Eden Brae no longer use general staircase for their stairs. Has anyone had experience dealing with the new company (not sure of the name), we are a little worried as the selection is through photos. The new staircase company is a sub division by Kitchen Culture. They are new to staircases. Make sure you keep good records and leave yourself plenty of time in finalising the stairs. Re: Who else is building with Eden Brae? 15473Feb 18, 2020 12:34 pm InvincibleInDN mckenzie Has anyone requested a fan provision with eden brae(but not the fan) or installed it after handover? They will charge you $40 to add Noggins. With the experience, I have if don't need any support. But you need wiring and switch for the fan. You can do the wiring as well if yours is single storey or the fan provision is on first floor. Oh my gosh, they charged me $119 for each 'switch wire for fan with noggin', is this the same as the $40 noggin? Who else is building with Eden Brae? 15474Feb 18, 2020 12:40 pm Huggies InvincibleInDN mckenzie Has anyone requested a fan provision with eden brae(but not the fan) or installed it after handover? They will charge you $40 to add Noggins. With the experience, I have if don't need any support. But you need wiring and switch for the fan. You can do the wiring as well if yours is single storey or the fan provision is on first floor. Oh my gosh, they charged me $119 for each 'switch wire for fan with noggin', is this the same as the $40 noggin? Yep. thats a lot of money for a bit of 40x30mm off cut with a couple screws each side. Cheers Brickface Re: Who else is building with Eden Brae? 15475Feb 21, 2020 11:28 am Steven_La SaveH2O Re the first flush, the 900mm head is a council requirement, a first flush diverter cannot be fitted to the downpipe. Stipulating a set 900mm head is amateurish at best. The detention drainage is designed for a 1:100 ARI. A 1:100 ARI has about 50% more intensity than a 1:20 ARI EDIT: Of interest, does your site have an impervious area greater than 70%? Your council requires any residential site with an impervious area exceeding 70% to have an onsite detention system. I don't know if my site is an impervious area or not, but only my block ( out of 6 blocks ) required that detention system. I was asking them why I had to have that system and the answer was, that is requirement for my house to be built after the hydraulic check by builder engineer. They gave me only 7 days to accept that variation or my build would be delayed. I chose to signed, didn't want the build to be more delayed. I have somewhat a similar story. During contract time, they included a provisional allowance of $8k for Hydraulic system. I had no idea what that was but they said it is required. Then after DA approval was received, they took 3 weeks to get the "Hydraulic plans" generated by the Hydraulic engineer who is basically Ibrahim Stormwater consultants (http://www.stormwater.net.au/) who returned a plan and quoted EBH for something. then EBH quoted me around $8k for the system which then i discovered that it is setup and material for the Rainwater or stormwater system. Although they have factored the Provisional Allowance since beginning, I was upset because in the original contract, they already mentioned that the Rainwater tank is included but then in the PCV quote, they said it has to be replaced with Kingspan and quoted 2500+ for that alone which did not make sense to me. Anyway I pretty much did what you did, proceeded so they can proceed asap because it has already taken a long time with fiddling around the PCVs and other paper work. cant wait any longer to see the actual works start on the ground. But i am still not convinced with the way this Hydraulic system been quoted. Re: Who else is building with Eden Brae? 15476Feb 21, 2020 12:38 pm 3 weeks is ridiculous. They use a template and the site drawing and calculations are quick and easy. Money for jam. Do you know what % of impervious area you have? This is almost certain to be the reason. See council website. To be withheld information is to be treated with disrespect. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who else is building with Eden Brae? 15477Feb 21, 2020 1:48 pm well, I certainly still lack the understanding of this. would appreciate if you share some knowledge or examples here. if it helps, the house is being built on a vacant land now. almost flat. My understanding so far is that the stormwater system was for the house only (i figured that out from the pipes on the plan they provided). my plan only has a drive way to the house as concrete. rest is soil/loan. Re: Who else is building with Eden Brae? 15478Feb 21, 2020 1:55 pm The builder should be able to tell you your impervious area. Maybe seeing the council is a better option. Just not good enough for the builder not to tell you. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Who else is building with Eden Brae? 15479Feb 21, 2020 6:18 pm what should that reveal? like if it is more than x% then A,,, if it is less than x% then B ..?? Re: Who else is building with Eden Brae? 15480Feb 25, 2020 10:38 pm sumur1au We are currently building a Waldorf and wondering where the best place to put the microwave, the display home has the unit in the pantry. Some display homes have the microwave in the Galley, looking for suggestions from others that have built a Waldorf on other practical locations and pictures if you can share. We’ve had it in the gallery and had no issues as per the display home. Kind Regards, Bruce "Building an Eden Brae Waldorf 50 in North Kellyville" Blog: http://waldorf50.blogspot.com.au A Mobile Solicitor at Wong & Horta Lawyers Website: http://www.whlawyers.com.au I built with EB back on 2009. Check out this thread on this forum. viewtopic.php?f=31&t=12911&p=154061#p154061 I can't speak for recent expericience however, we had no… 1 24066 A survey must’ve completed by a certified surveyor. This form part of every DA requirement 3 226326 |
