Browse Forums DIY, Home Maintenance & Repair Re: Grinding concrete flush with brick wall 3Jan 29, 2020 1:00 pm meminiau How is this going? Have you done the job yet? If it was my place I would just keep using the Jack hammer on the concrete until it was flush. Yeah, sorry about the late reply. I purchased a segmented diamond cut off wheel for my 5" grinder and made a series of vertical cuts about 10mm apart, then chipped them away with a hammer. Will probably get some epoxy filler to repair the areas of concrete that have broken away/level the surface in preparation for a deck ledger board to be installed. Cheers The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 16262 Okay, then the choice is really about the build quality of the door itself which means the brand name. Sorry I can't recommend one or the other so best to rely on comments… 5 3713 Hi there, looking to have a gym in a new build. Planning to install some sort of rubber mat flooring (on concrete) i.e. Asking the builder to not do floorboards in the gym… 0 2957 |
