Usually they give you sample contract which is standard before the external appointment, I signed it on the same day
Browse Forums Building A New House Re: McDonald Jones Homes - The new thread 14406Dec 17, 2019 8:53 pm MJH is requesting for me, the owner, to build the retaining wall after hand over. Is this normal? I thought it should be built right after cut and fil and before slab. Then the excavators for the wall can still enter the back yard Re: McDonald Jones Homes - The new thread 14407Dec 17, 2019 10:53 pm stevenboh MJH is requesting for me, the owner, to build the retaining wall after hand over. Is this normal? I thought it should be built right after cut and fil and before slab. Then the excavators for the wall can still enter the back yard Depends on what is needed. If you need before the builder will inform you. Majority retaining walls are built after. The nearby lots can affect after being cut & filled during the built. Always good to built after as situations change by the end of a built. Re: McDonald Jones Homes - The new thread 14408Dec 18, 2019 6:45 am stevenboh MJH is requesting for me, the owner, to build the retaining wall after hand over. Is this normal? I thought it should be built right after cut and fil and before slab. Then the excavators for the wall can still enter the back yard If your land is not stable after they cut and fill then you will have to do a retaining wall before they start to build ..That is usually after your slab is done. Re: McDonald Jones Homes - The new thread 14409Dec 18, 2019 6:59 am Kery_deep Depends on what is needed. If you need before the builder will inform you. Majority retaining walls are built after. The nearby lots can affect after being cut & filled during the built. Always good to built after as situations change by the end of a built. Outerwest If your land is not stable after they cut and fill then you will have to do a retaining wall before they start to build ..That is usually after your slab is done. Thanks, I will confirm with the builder, but I get the feeling they want me to do it after handover so they can finish the construction quicker. So it's not for the right reasons. The cut and fill is going to make my land and my neighbours a 1m height difference, so it's not a major difference. Re: McDonald Jones Homes - The new thread 14410Dec 18, 2019 7:08 am stevenboh Thanks, I will confirm with the builder, but I get the feeling they want me to do it after handover so they can finish the construction quicker. So it's not for the right reasons. The cut and fill is going to make my land and my neighbours a 1m height difference, so it's not a major difference. A 1 metre difference in slab height is quite noticeable depending on the block size. I'm sure that it may need to be engineered too. Will the retaining wall need to installed on your boundary? Re: McDonald Jones Homes - The new thread 14411Dec 18, 2019 7:12 am [quote="Supercharger":2u3shpxd][quote="stevenboh":2u3shpxd]Thanks, I will confirm with the builder, but I get the feeling they want me to do it after handover so they can finish the construction quicker. So it's not for the right reasons. The cut and fill is going to make my land and my neighbours a 1m height difference, so it's not a major difference.[/quote:2u3shpxd] A 1 metre difference in slab height is quite noticeable depending on the block size. I'm sure that it may need to be engineered too. Will the retaining wall need to installed on your boundary?[/quote:2u3shpxd] Yes on the boundary, I am currently getting an engineer to draw up structural designs and lodging for CDC approval, as requested from the builder. I will see what the landscaper and engineers opinion is for the timing of wall. If it is okay to do after handover or before slab but after cut and fil. Re: McDonald Jones Homes - The new thread 14412Dec 18, 2019 7:39 am stevenboh \"Supercharger":2u3shpxd \"stevenboh":2u3shpxd Thanks, I will confirm with the builder, but I get the feeling they want me to do it after handover so they can finish the construction quicker. So it's not for the right reasons. The cut and fill is going to make my land and my neighbours a 1m height difference, so it's not a major difference.[/quote:2u3shpxd] A 1 metre difference in slab height is quite noticeable depending on the block size. I'm sure that it may need to be engineered too. Will the retaining wall need to installed on your boundary?[/quote:2u3shpxd] Yes on the boundary, I am currently getting an engineer to draw up structural designs and lodging for CDC approval, as requested from the builder. I will see what the landscaper and engineers opinion is for the timing of wall. If it is okay to do after handover or before slab but after cut and fil. As MJH have control of the site it will be up to them to decide when the retaining wall is built. If it's required before a slab can be poured you will have to do it now. Re: McDonald Jones Homes - The new thread 14413Dec 18, 2019 8:34 am stevenboh Kery_deep Depends on what is needed. If you need before the builder will inform you. Majority retaining walls are built after. The nearby lots can affect after being cut & filled during the built. Always good to built after as situations change by the end of a built. Outerwest If your land is not stable after they cut and fill then you will have to do a retaining wall before they start to build ..That is usually after your slab is done. Thanks, I will confirm with the builder, but I get the feeling they want me to do it after handover so they can finish the construction quicker. So it's not for the right reasons. The cut and fill is going to make my land and my neighbours a 1m height difference, so it's not a major difference. 1m is quiet a lot of difference. Re: McDonald Jones Homes - The new thread 14414Feb 11, 2020 11:09 pm Are retaining walls generally built on the boundary? The certifier requesting that I build it wholly within my property. But when the fence eventually gets built, I would have through it would be built on top of the retaining wall, on the boundary Re: McDonald Jones Homes - The new thread 14415Feb 11, 2020 11:43 pm If both the neighbours need to retain, the wall needs to be on the boundary so the cost also is shared. But if you are doing it yourself it has to be entirely Within your boundary. If you have enough room behind the wall the fence can go on the boundary, but this depends on the fall and if suitable to building the fence. We are doing the same. We have an egline between the boundary & our retaining wall but we can still put a fence on the boundary following the slope. Totally on the situation. Re: McDonald Jones Homes - The new thread 14416Mar 21, 2020 6:43 pm Hi All, We are currently building a San Marino and writing about the experience. We’ve had a lot of help and inspiration from other people’s blogs, so if anyone’s interested you can check ours out at: sanmarinoexec16.blogspot.com Re: McDonald Jones Homes - The new thread 14417Mar 22, 2020 11:49 am Justin N Dee Hi All, We are currently building a San Marino and writing about the experience. We’ve had a lot of help and inspiration from other people’s blogs, so if anyone’s interested you can check ours out at: sanmarinoexec16.blogspot.com Very nice, did you opt for fast track ? We are building a single storey, started site excavation 22/01/20 and now up to plastering stage It feels like it will all be done in another 2 months meaning a quick 4 month build time ! I hope the Covid-19 issues do not effect the build time too much Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: McDonald Jones Homes - The new thread 14418Mar 22, 2020 2:58 pm stevenboh Justin N Dee Hi All, We are currently building a San Marino and writing about the experience. We’ve had a lot of help and inspiration from other people’s blogs, so if anyone’s interested you can check ours out at: sanmarinoexec16.blogspot.com Very nice, did you opt for fast track ? We are building a single storey, started site excavation 22/01/20 and now up to plastering stage It feels like it will all be done in another 2 months meaning a quick 4 month build time ! I hope the Covid-19 issues do not effect the build time too much Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi stevenboh, We were never offered a fastrack, but we feel like the progress has been fairly quick since excavation started. Your build sounds like it's going ahead very quickly, and its looking great! We'd love if ours was completed in 4 months! We have a contract date in October for completion, but hoping it will be a bit sooner than that. All the best with it! Re: McDonald Jones Homes - The new thread 14419Jun 07, 2020 7:45 pm Has anyone got any facade pics of tudor beige ? Im pretty sure this is the color i want on the hebel but would love to see it on a home, im thinking tudor beige , woodland grey roof and walnut stain on the merbau post I said after the 1st build “ never again “ & now im on my 3rd Re: McDonald Jones Homes - The new thread 14420Jun 07, 2020 8:49 pm santafe JLL3 Just wondering if people have signed their building contract on the spot at the same day as their external appointments OR did they take the contract home first to review then sign? Usually they give you sample contract which is standard before the external appointment, I signed it on the same day I took it home and went through it, sent a copy to the solicitor. They highlighted a few things just to make sure we understood. Building a Havana Executive therayworthsbuild.wordpress.com Hi AKG, We had a base tender of $592 for 31 squares from MC Donald Jones. It looks relatively cheaper than other builders. But I assume there are many hidden things that… 1 17519 Hi, Apologies - I know there is plenty out there on this but struggling to put together the puzzle. We're planning our garage/external laundry to master bedroom and… 0 12612 Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs… 0 26675 |
