Browse Forums Owner Builder Forum Re: Side and rear setbacks 3Dec 12, 2019 12:02 pm Stewie D It'll depend a lot on your council ( you don't say where you are ). Some are tougher than others. The surveyor can also certify it as an alternate solution but you may have to clad that wall plus eaves etc out of non-flammable materials. "You rely on the concreters to make sure that the slab is in the right location" The builder is the one who should set out the slab not a concreter. Stewie Hey Stewie. I mean the opposite to what your saying.. bringing the wall out. I'm saying if your side setback is supposed to be 0.9 metres but your house is bigger and all you have is 0.8 Re: Side and rear setbacks 4Dec 12, 2019 2:26 pm No, I know exactly what you are saying. If the NCC and council regs say 900mm from the boundary to the wall and you end up with only 800mm then it is non-compliant. However, as per my first post " The surveyor can also certify it as an alternate solution but you may have to clad that wall plus eaves etc out of non-flammable materials. ". The 900mm is there as a way of a fire break between buildings should one of them become aflame. When you go less than that you may be required to increase the fire resistance of your house. Stewie Re: Side and rear setbacks 5Dec 12, 2019 3:47 pm Stewie D No, I know exactly what you are saying. If the NCC and council regs say 900mm from the boundary to the wall and you end up with only 800mm then it is non-compliant. However, as per my first post " The surveyor can also certify it as an alternate solution but you may have to clad that wall plus eaves etc out of non-flammable materials. ". The 900mm is there as a way of a fire break between buildings should one of them become aflame. When you go less than that you may be required to increase the fire resistance of your house. Stewie My house is already cladded using masterwall. No bricks My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 7418 Hey everyone Not for me or anyone I know, just generally interested. For a single allotment house, are you allowed to take the fence on both sides of your house and… 0 21631 |
