Browse Forums Building A New House Re: Brisbane - Building and Energy Efficient Home 17Sep 20, 2019 7:18 am Hi, I would have thought the foam/foil option would be best in terms of blocking radiant heat and on your link it has the same R value as fibreglass. Also with fibreglass you always have the risk of not being installed well and compressed etc. Also I agree with your re:roof sarking that in the warmer zones reflective foil is best....or why not get the best of both worlds and go anticon blanket....foil with fibreglass attached. --------------------------------------------------------------------- Check our Homeone build blog here Re: Brisbane - Building and Energy Efficient Home 18Oct 22, 2019 5:08 pm Hi All My first post here. Not sure if you have finally found your solution, but I'm building an R4 insulated home but not using brick veneer. As it's not just about the walls insulation its also your air leaking of the building envelop as that would be another thermal loss. Of course this is aong with correct windows frames, glazing and shading. I can upload pictures of my build to show you what we are doing. Re: Brisbane - Building and Energy Efficient Home 19Oct 22, 2019 5:23 pm Hi Momarvel, yes I am interested in any more information you have to share. Re: Brisbane - Building and Energy Efficient Home 20Oct 24, 2019 2:54 pm Hi See attached photos. All external walls are from structural 140mm timber with EPS panels with fibre cement sheets. As the external walls are constrcuted all the joints are glued and nailed into timber studs. External walls are than render finished. Insulation of R3.75 Hope that helps Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 2431 Hi, does anyone have a clue how the Brisbane Development website work in terms of how uptodate the dates on it are (developmenti.brisbane.qld.gov.au). I transfered… 0 4937 Give "Holt Surveying" they are based around Eight Mile Plains 3 11685 |
