Browse Forums Building A New House Re: Private inspector 4Apr 24, 2019 12:38 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Private inspector 5Aug 08, 2019 7:51 am The clause constitutes an Unfair Contract Term, check the ACCC website for further information. The clause also reflects the builder's lack of confidence in their QC system and their ability to deliver a good product. The clause also reflects the builder's lack of respect for their client. This lack of social conscience is why having a pre contract signing consultation with an industry expert is so important.Consider it like examining a map prior to making a trip to an unknown destination. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Private inspector 6Aug 08, 2019 8:18 am Try to get included in the contract that progress payments are only payable after the private inspector has inspected and confirmed the work done for that stage is per the contract and meets the applicable building standards. Otherwise an unscrupulous builder will simply ignore the inspection report, assure you it will be ok, they will fix it later etc...and just invoice you anyway. Pay attention to liquidated damages amounts because these can allow an unscrupulous builder to use time and financial pressure against you if they don’t want to rectify defects. Re: Private inspector 7Aug 09, 2019 12:07 pm As far as I know, the private Building Inspector is your agent. They represent you, so there is no way they should be charging you extra. Re: Private inspector 8Aug 09, 2019 5:48 pm Private inspectors add cost for the volume builders like Metricon and their comparatively low paid volume contractors. They don’t want you finding deviations from the plan and poor workmanship during the build and your requests to rectify it at their expense. They would prefer to keep going and cover these up or that you find the defects later at PCI or after handover when they have all your money and it’s just not practical to fix. Do not expect your builder, like Metricon in my experience, to have a quality checking process during the build. This requires expensive skilled labour and their high volume / low cost business model does not make such a process viable. The site supervisor may manage up to 20 builds at a time and will have minimal time to visit and check yours. It is up to you and your inspector to check their workmanship and conformity to the plans. However, every customer’s expectations and tolerance of defects with volume builders will be different. If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 26249 I would send it to the certifier who is technically your representative and working on your behalf not the builder's 1 2554 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 12293 |
