Browse Forums Building A New House Re: Metricon - Savannah 40 - Adelaide Athelstone 94Jun 26, 2019 12:15 pm craigo Renman What is your networking setup and did Metricon install it for you? Cat 6 all ran back to garage with a 16 port gigabit switch, couple of patch panels, just plug in the modem and away you go. We have NBN to the premise but will probably just put a 5G modem in there as it's available in our area and min 10x faster than NBN. Did they terminate the Cat6 cables with a RJ45 connector for you? They are refusing to do it for our build stating that it's not in their scope? Re: Metricon - Savannah 40 - Adelaide Athelstone 95Jun 26, 2019 3:32 pm Renman craigo Renman What is your networking setup and did Metricon install it for you? Cat 6 all ran back to garage with a 16 port gigabit switch, couple of patch panels, just plug in the modem and away you go. We have NBN to the premise but will probably just put a 5G modem in there as it's available in our area and min 10x faster than NBN. Did they terminate the Cat6 cables with a RJ45 connector for you? They are refusing to do it for our build stating that it's not in their scope? Some builders do, some don't , Mine did but it doesn't not matter , However, since it was outside the brick wall the connector all was dusty and expose to moisture. So I have to redo them. Re: Metricon - Savannah 40 - Adelaide Athelstone 96Jun 26, 2019 3:32 pm Renman Did they terminate the Cat6 cables with a RJ45 connector for you? They are refusing to do it for our build stating that it's not in their scope? That's so random! All ours were done, they even supplied the switch. Re: Metricon - Savannah 40 - Adelaide Athelstone 97Jun 26, 2019 6:03 pm dulie Renman Did they terminate the Cat6 cables with a RJ45 connector for you? They are refusing to do it for our build stating that it's not in their scope? That's so random! All ours were done, they even supplied the switch. Building a new home, and looking for a garage builder (home builder not contracted to do this). Someone to build steel garage (double), colorbond, including supply and… 0 3582 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 12935 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 9811 |
