Browse Forums Building A New House Re: Brand new house - Rising damp issue 10May 29, 2019 3:10 pm 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Re: Brand new house - Rising damp issue 18May 29, 2019 7:22 pm Why not get a treatment for efflorescence, if it continues to come back or you notice other evidence, then request another inspection. Have a look when it rains as well and see where the water is trickling. Re: Brand new house - Rising damp issue 19May 29, 2019 7:36 pm From my experience the efflorescence is a results of excess water then drying which leaves the residue so the problem may not be there now.Was it a wet period during the construction with poor drainage and no temporary downpipes? I would get a soil test next to your perimeter wall with soil moisture content testing from a geotech company.I noticed you have pebble landscaping, this is a bad idea especially with a H1 soil type.The pebble landscaping will allow water to penetrate into the ground and then restrict evaporation gradually leading to an increase in soil moisture around the perimeter of the house.Apart from rising damp this can lead to slab heave, I would remove the pebbles and either grade the soil away from the house or place plastic down which grades way from the house and then put landscaping material on top. Re: Brand new house - Rising damp issue 20May 29, 2019 7:55 pm sweetswisssteel Why not get a treatment for efflorescence, if it continues to come back or you notice other evidence, then request another inspection. Have a look when it rains as well and see where the water is trickling. I am still in the pre purchase stage where I have signed a contract and I have building and pest condition for 21 days, I have another 14 days left to arrange an inspection done by a specialist and find out what the issue is and also suggest a remedy. The builder says there is no issue but he is happy for us to do what ever tests within the next 14 days. If you can suggest if I should engage a plumber ? Damp specialist? Concrete specialist? Or a structural engineer then i can take the next course of action. At the moment I am not sure whom to consult Pay again? No retribution? Your glass has a specific performance get this app and see how much your windows are leaking, then challenge the supplier. 3 5113 Have look at your house plans and you will probably find that brick articulation joint has been missed. Maximum allowable spacing is 6M or 5.5M for a wall with window… 17 21290 Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 8315 |
