Browse Forums Landscape & Garden Design Re: Storm Water Outlet on Acreage site | Options? 2May 29, 2019 7:20 am Dazzy Once the house is up, I would expect more run off from the roof ect Not sure why that would be the case. Wouldn’t the roof area be similar to the ground area below it that was there before the house was built. Moreover, I wonder why you wouldn’t be catching the rainwater that is running off your roof for use in the house and garden? Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7998 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6976 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10735 |
