Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 801Apr 12, 2019 1:40 pm Build thread: viewtopic.php?f=31&t=32574 Re: I work in flooring - do you have a flooring question? 802Apr 12, 2019 2:03 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 803Apr 12, 2019 2:18 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 807Apr 18, 2019 7:29 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 809Apr 18, 2019 7:40 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 810Apr 18, 2019 7:42 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 812Apr 18, 2019 7:45 pm Buildingindoreen Michelle Buildingindoreen Hi Michelle! We are looking at building our frst home through a small builder in Melbourne. I'm just wondering if you would recommend Vinyl flooring of timber laminate? Our builder has advised it will be $100m2 installed as opposed to $65m2 installed for timber laminate, I'm not sure it will be worth the additional cost to simply have Vinyl. Do these costs seem reasonable or should we seek quotes elsewhere for the flooring? Hi there..... this is a common question. As a building and flooring consultant, these are my questions to my clients. How do you live in your house, do you take your shoes off, do you REALLY live in your house and give your flooring a hard time? Replacing a vinyl plank is soooo much easier than replacing laminate planks. DO you like quiet? Vinyl will give you quiet! Do you like to look of real timber over plastic looking?? Laminate is the go. I prefer the vinyl, but that's just me. Laminate is too drummy for me. Do you have kids? It will be loud...... It really is a personal choice. Most of the time it will come back to $$$ do what suits you best. If you are going with a laminate, make sure its one of the water proof types! I hope this has helped!! Thanks so much Michelle, this is so helpful. What do you think o the prices I have been quoted by my builder? Should I look into arranging my own flooring after handover? It will ALWAYS be cheaper to do after handover. Remember, your builder is making money the best way he can, most of the private builders are happy for you to take the flooring burden off them. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 813Apr 18, 2019 7:57 pm By the way... $65m2 is very cheap, not water proof and probably only 7mm, look into to that!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 814Apr 18, 2019 8:04 pm It seems maybe people are missing the Hybrid thing.....let me explain. Hybrids are a combination of vinyl with a locking system like a floating floor. So basically it is a floating vinyl floor. You still need the expansion gap of about 2mm around the room, cover with either skirting or Scotia. Its a floating vinyl floor...water proof as all vinyl is. Questions?? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 815Apr 18, 2019 8:18 pm Michelle By the way... $65m2 is very cheap, not water proof and probably only 7mm, look into to that!! Thanks Michelle. Is $100m2 for Vinyl reasonable? I will ask them about a hybri as well. Where does that sit price-wise in comparison with the other two options? Re: I work in flooring - do you have a flooring question? 816Apr 18, 2019 8:30 pm Buildingindoreen Michelle By the way... $65m2 is very cheap, not water proof and probably only 7mm, look into to that!! Thanks Michelle. Is $100m2 for Vinyl reasonable? I will ask them about a hybri as well. Where does that sit price-wise in comparison with the other two options? Yes, its close, not knowing what vinyl they are quoting you on?? You need to find that out also, which brand? Karndean do a locking clip which is around $110 installed, others are slightly cheaper. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 817Apr 18, 2019 8:31 pm Michelle Buildingindoreen Michelle By the way... $65m2 is very cheap, not water proof and probably only 7mm, look into to that!! Thanks Michelle. Is $100m2 for Vinyl reasonable? I will ask them about a hybri as well. Where does that sit price-wise in comparison with the other two options? Yes, its close, not knowing what vinyl they are quoting you on?? You need to find that out also, which brand? Karndean do a locking clip which is around $110 installed, others are slightly cheaper. Yes it's Karndean that they've quoted. I think I'll have to look into it more, it's sounding pretty great! Re: I work in flooring - do you have a flooring question? 818Apr 18, 2019 8:43 pm Getting a bit over loosing my posts here!! Go to a Choices flooring store, they will be able to give you all the info you need. In fact MOST flooring stores keep Karndean! De Novo Concepts - http://www.denovoconcepts.com online building advice Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 819Apr 18, 2019 8:46 pm Michelle Getting a bit over loosing my posts here!! Go to a Choices flooring store, they will be able to give you all the info you need. In fact MOST flooring stores keep Karndean! De Novo Concepts - http://www.denovoconcepts.com online building advice Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks so much Michelle, I will do that Re: I work in flooring - do you have a flooring question? 820Apr 23, 2019 3:42 pm Hi Michelle, The planting hybrids are advertised to be fade resistant but the korlok by karndean don't mention it at all. Between the karndean and proline rigid cores... What would you put down? Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 41398 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 11167 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 5054 |
