thanks a lot .
I'll probably stick to the abode noble.
Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 764Feb 19, 2019 5:01 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 767Feb 24, 2019 3:31 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 772Feb 24, 2019 5:47 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 773Feb 24, 2019 5:51 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 775Feb 25, 2019 5:35 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 776Feb 25, 2019 8:21 am thanks but isn't Ritola an eternity carpet also? Re: I work in flooring - do you have a flooring question? 777Feb 25, 2019 5:03 pm Taniaimran thanks but isn't Ritola an eternity carpet also? Yes, its in the Choices group called Eternity. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 778Feb 27, 2019 3:18 pm HI Michelle Just have stupid question if you don't mind it. 1- is this Hybrid Flooring ? Could not find Hybrid Flooring on choicesflooring website. https://www.nationaltiles.com.au/flooring/shop-by-type-flooring/hybrid?gclid=EAIaIQobChMIyZeT1pDb4AIVziMrCh0Vpgz_EAAYBCAAEgISpfD_BwE 2- Above mentioned Hybrid Flooring from National Tiles is 6 mm Thick. My builder put skirting as prime or nailed rather than tack or glue. Would 6 mm thickness is a problem ? I heard under 5 mm thickness skirting prim or nail is not a problem. I could be wrong Thanks Re: I work in flooring - do you have a flooring question? 779Feb 28, 2019 5:47 am nafeesra The choices website on the vinyl page - the first 2 lines are the abode range, they are the hybrids. Yes, not very well advertised I have to say. https://www.choicesflooring.com.au/viny ... ing-range/ Yes, it seems your link is a hybrid flooring. Not quite sure what you are meaning with the skirting, we install 14mm floating floors plus 2mm underlay under skirts, no problem. De Novo Concepts Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 780Mar 02, 2019 12:08 pm Hi all, I thought I would post some recent photos of a project I did the end of last year. This is a holiday rental at Coolangatta NSW on the south coast. Full renovation, internal and externals. The flooring I chose was Karndean looselay long boards in French Grey Oak. I went straight over the existing tiles with a skim coat of ardex first. My client is very happy with m y chosen flooring for investment. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ 1 comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ De Novo Concepts - Online Consultations world wide. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 40927 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10469 1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey… 0 4788 |
