Browse Forums Outdoor Living Re: Can u deck over existing concrete slab? 34Jan 23, 2015 7:23 am Build Thread: viewtopic.php?f=31&t=57639 Re: Can u deck over existing concrete slab? 36Mar 10, 2015 3:45 pm http://camdenbuild.blogspot.com.au/ by invite only please pm me Re: Can u deck over existing concrete slab? 40Feb 12, 2019 11:13 am Novicehandyman We want to deck over our alfresco slab which is relatively flat but also extend out over a concrete path which has a small slope to allow water run off. Is it possible to deck this and keep it all level? From the sounds of your requirement, theKlevaklip (refer video -> www.klevaklip.com.au/How-to-build-a-dec ... crete-slab ) should be the solution to raise and level the deck. Blog @ The Desire One corner of my shed slab will be directly over a 1400mm diameter concrete soakwell. Is it feasible to fill the soakwell with concrete then lay the shed slab over the… 0 1222 Much a do about nothing. You can see the fall heading to the actual drains. Stormwater ingress will be minimal and it's far better to have the top sitting flush rather… 12 6472 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5951 |
