Browse Forums Building A New House Re: Building with Wisdom Homes 13262Nov 04, 2018 6:23 pm Wisdom Homes Manhattan 39 Blog - https://edmondson-park.blogspot.com.au H1 Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=88210 Re: Building with Wisdom Homes 13267Nov 05, 2018 11:59 am BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Re: Building with Wisdom Homes 13275Nov 07, 2018 5:18 pm Hi guys, looking at Submission Plans and I see a mention of Retaining Wall and immediately panic because I know these can be an expensive cost. Anyway, can any one tell me if the below looks like it's going to be an expensive job - based on size? Can it be done after handover or does it need to be in place in order to get OC? TIA! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Wisdom Homes 13276Nov 07, 2018 6:13 pm ASJ1981 Hi guys, looking at Submission Plans and I see a mention of Retaining Wall and immediately panic because I know these can be an expensive cost. Anyway, can any one tell me if the below looks like it's going to be an expensive job - based on size? Can it be done after handover or does it need to be in place in order to get OC? TIA! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had the same on our plan but no one could explain why as our block is pretty much level. It was taken off the plans after we questioned it. Re: Building with Wisdom Homes 13277Nov 07, 2018 6:17 pm jqcc0 ASJ1981 Hi guys, looking at Submission Plans and I see a mention of Retaining Wall and immediately panic because I know these can be an expensive cost. Anyway, can any one tell me if the below looks like it's going to be an expensive job - based on size? Can it be done after handover or does it need to be in place in order to get OC? TIA! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had the same on our plan but no one could explain why as our block is pretty much level. It was taken off the plans after we questioned it. That's what I was thinking - to question it as well because our land is pretty level too. But I thought if the Contour Survey says I need it, then I probably have no choice... Re: Building with Wisdom Homes 13278Nov 07, 2018 7:47 pm ASJ1981 jqcc0 ASJ1981 Hi guys, looking at Submission Plans and I see a mention of Retaining Wall and immediately panic because I know these can be an expensive cost. Anyway, can any one tell me if the below looks like it's going to be an expensive job - based on size? Can it be done after handover or does it need to be in place in order to get OC? TIA! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had the same on our plan but no one could explain why as our block is pretty much level. It was taken off the plans after we questioned it. That's what I was thinking - to question it as well because our land is pretty level too. But I thought if the Contour Survey says I need it, then I probably have no choice... It looks like your land slopes 200mm down from right to left over the length of that retaining wall. Can't see whether your house is cut or filled at that point relative to the natural ground level. IF you need a wall it doesn't look like much to me. Building Manhattan 44 Ens + Savannah Elite facade KDRB Tender Accepted 26/03/18; Contract signed 27/05/18; CDC submission 24/10/18; End Panel 13/02/2019; Slab 19/03/2019 Re: Building with Wisdom Homes 13279Nov 07, 2018 9:58 pm Jenifermarie Exhausting day but we got our keys yesterday Few small issue still outstanding. Our rain tank is being checked on Monday because it’s leaking and we have a Di Lorenzo rep coming out to inspect some of our tiling we’re not happy with. Had a locksmith on site because the pins didn’t drop properly on our front door so our key wouldn’t work. He was lovely despite the fact it was nearly 40C and he was working out the back of his truck. I felt terrible for him and our fencers working in that heat. Have found one major issue that wasn’t picked up at all during our inspections or by the private inspector and that’s that one of our stacker door frames is bowed along the bottom due to slightly uneven bricks. The doors themselves work ok but we had them measured for crimsafe screen doors and they fall off the rails because of the bowing. I will contact our SS on Monday but I suspect it will have to go on our 90 day maintenance list so there is something to look out for. Definitely a pro for having Wisdom complete your screen doors before handover. Take time get settled and enjoy your new place for all the hard work done since past 2 years . Cheers to both of you Re: Building with Wisdom Homes 13280Nov 08, 2018 6:17 am ASJ1981 Hi guys, looking at Submission Plans and I see a mention of Retaining Wall and immediately panic because I know these can be an expensive cost. Anyway, can any one tell me if the below looks like it's going to be an expensive job - based on size? Can it be done after handover or does it need to be in place in order to get OC? TIA! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi all dont worry about those retaining walls on the plan. Most likely things will change anyway depending on whether you would like to do additional cut or fill the side areas. It also depends on what your neighbour will be doing whether cutting/filling/maintain the natural ground level. Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19472 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 75108 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9823 |
