Browse Forums Flooring & Floor Covering Re: White risers for new stairs 9Oct 15, 2018 9:04 am arcadelt nada17 I was thinking of putting something over MDF just to make it smooth and paining it. MDF can be easily sanded smooth, but wear a mask when doing it. Use and appropriate undercoat and you can paint it any colour you like. Also, unless it is moisture resistant (which I doubt in that application), make sure to keep moisture away during the life of the house and it will last a long time. Are the stairs accessible from underneath? If so, you could alternatively ask your joiner to provide finished laminate boards to be secret-screwed to the risers from the back side. They can come in thousands of colours and finishes, including high gloss or textured even. Thank you! I am a bit concerned with moisture but I think it would only be exposed to moisture during cleaning. I am not sure though how they are are going connect the laminate to the riser. they will probably use some transition. not sure if it looks as good as I imagine will have to discuss it with the floor installer Re: White risers for new stairs 10Mar 11, 2021 1:51 pm Hello, I realise this is an old thread but thought I would see whether you succeeded in doing the laminate timber tread and painting your MDF risers? Or did you do something to the riser before painting? Thank you! Got my stairs designed like this with 250mm Gap marked below. Gap is bec of 2 steps added between two landing area… 0 4976 Move your linen into laundry and access laundry from your present linen space 1 8342 not sure how much but a “repair” should be ok, what ever that is technically 3 10242 |
