Browse Forums Building A New House Re: Building new home 2Jul 08, 2018 8:26 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Building new home 9Oct 21, 2018 11:06 pm michaelyoni64 Congrats for building. We wanted the design like the home on display and even though they said yes, it was not 100% same. Because you will make changes or they will "conveniently" omit things on the plan. A classic for us was the front wall lighting that was on the display home but not on the plans presented to us. We assumed it was. Big mistake. If you are happy with a particular room then note everything down to the measurements....eg number of powerpoints and where they are located and distance from wall and floor. Also make sure that wall light switches are all fed through conduits!!! Because nowadays the cheap way is to cut into the wall and cement the cables in. This then limits if you want to add an extra switch later on. I can go on. If you have any shower recesses in the walls make sure you stipulate that the sizes are finished dimensions not unfinished dimensions. Trust me. We are fighting them with this. Stipulate that the downpipes are on the corners and ends of the gutters also add extra....they will go for the minimum as per standards. Which after some rain they will overflow (happening to us now). You have to make it black and white. Everything. Assume nothing and assume they are dumb. Every meeting you have with builder write down everything you want changing or adding. Then only discuss those and give them a copy of that list. Also then follow up with an email confirming the meeting you had with XYZ you discussed this and attach the same paperwork. During our plan some things discussed with one person was not transferred to the next (we had 3 diff project managers over 6 months planning due to quitting, marriage and baby!. After all done "they have no record" of those changes or additions we discussed. So cross check everything. Don't be forced into signing and commencing when they are ready. Only when you are ready. I can go on and on. But enjoy the experience!!! Keep us informed. Thankyou for your input. I have just brought the block after thinking a while about it. I will do as you have advised. Thankyou very much Re: Building new home 10Nov 04, 2018 12:43 am No. Homezone. We have had our 6month inspection. Found more problems and they have literally given me the bird.. Re: Building new home 11Nov 04, 2018 12:45 am Lynnly.... make sure you are specific at anything you want to be at a certain size. Even to the point of giving a tolerance. Re: Things you forget - summary page 32 12Mar 21, 2019 10:18 am michaelyoni64 Stipulate that the downpipes are on the corners and ends of the gutters also add extra....they will go for the minimum as per standards. Which after some rain they will overflow (happening to us now). Builders position downpipes at the end of walls for aesthetics, not good design. A hipped roof has small roof areas at the end of walls. When downpipes are positioned at the end of walls (as most are), water flowing off the largest roof area away from the downpipes has a longer run than if the downpipe was positioned close to the largest roof surface area, the reason why most overflows not caused by blockages happen away from the downpipes. Corners also slow down the flow, something that isn't factored for compliance. Downpipes are also best not fitted to the end of a gutter because the slope will always promote sediment and decaying organic matter building up in the short length of gutter between the downpipe's pop and the gutter's end cap. Metal is positive charged whereas sediment is negatively charged which is what promotes rusting. Compliance does not guarantee good design. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Is it just a report written to give to the bank initially and it is based on what and how your payments are made up for, or is it a full service where they go out and… 2 6004 Hi Suku18 In NSW the statutory required insurances are: 1. HBCF ( Home Building Compensation Fund) - This is if the builder dies or goes broke. But this only covers 20%… 1 3093 Skjm You might want to watch this video: https://www.youtube.com/watch?v=CKx-bsOr2jg If that link doesn't work go to youtube and search for Zac Homes ACA I am really… 1 4185 |
