Browse Forums Landscape & Garden Design Re: Block wall cost 2Sep 05, 2018 10:14 pm Besser blocks S&I (with reinforcement and concrete pour) - $180-200 per sqm (+GST) without render. Footings - roughly 250x600x15m=2.25 cu*$260=~$600 for concrete, $300 for reo and around $1000 for labour including excavation. Plus pump cost for two pours (may be around $600-800 per pour). So roughly around $5.5K+GST. Re: Block wall cost 3Sep 06, 2018 11:42 am Plus engineer cost as it's very likely you'll need it for a wall that high so check with your council to see at what height they require engineering. Re: Block wall cost 4Sep 06, 2018 11:51 am Generally engineering certification is required if the wall is above 1 m. But Besser blocks reinforcement + footings reinforcement needs to be specified. The footings will be likely be 1000 wide though, not 600. Re: Block wall cost 5Sep 06, 2018 8:50 pm alexp79 Generally engineering certification is required if the wall is above 1 m. But Besser blocks reinforcement + footings reinforcement needs to be specified. The footings will be likely be 1000 wide though, not 600. My council requires them above 600. Just sayin. Re: Block wall cost 6Sep 07, 2018 4:29 pm Pro tip: we are using versawall from adbri masonry for our wall. They supply a technical data sheet that can be used to satisfy the requirement for engineering, as long as you build the wall to those specifications! It's not a requirement to engage a civil engineer to design a wall, at least in my council. Re: Block wall cost 7Sep 08, 2018 3:29 pm Guys. The rules regarding engineering also apply at any height wall (yes, even 30cm) within 1 metre of a boundary. there is a standard besser block wall pdf somewhere online with footing sizes, also have a look at dincel. 1 10304 Beautiful thing with the shelf/recess lintel is you just use maxi's so standard brickwork. All the brickies and roofers in Perth are used to this style so there is… 7 6338 Thank you alexp79 and gommeqld for your advice, that's very helpful, thanks 3 19142 |
