Browse Forums Building A New House Re: Building Arden homes Votivo 37 in South East 463Aug 14, 2018 11:26 pm _________________________________________ Regards Manj https://forum.homeone.com.au/viewtopic.php?f=31&t=88256 Re: Building Arden homes Votivo 37 in South East 464Aug 15, 2018 12:47 am follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 466Aug 15, 2018 7:17 am Build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=88062 Re: Building Arden homes Votivo 37 in South East 467Aug 17, 2018 6:39 pm follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 469Aug 19, 2018 7:41 am So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? Ezza it will be corrected - I showed to my SS my contract showing false bottom in cabinet charged around 170 and also electrical drawing showing the lights r in the centre of cabinets. Will be changed now and put into cabinets follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 470Aug 19, 2018 8:23 am So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? We asked for the same as well, but can't find any reference to it being recessed anywhere on my plans or contract. Will need to confirm with my CSA. Re: Building Arden homes Votivo 37 in South East 471Aug 19, 2018 8:40 am So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? We asked for the same as well, but can't find any reference to it being recessed anywhere on my plans or contract. Will need to confirm with my CSA. It looks ridiculous - better have a look. follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 472Aug 19, 2018 8:57 am So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? Ezza it will be corrected - I showed to my SS my contract showing false bottom in cabinet charged around 170 and also electrical drawing showing the lights r in the centre of cabinets. Will be changed now and put into cabinets PEast, I’m worried because my drawing doesn’t show a false bottom but we were told would need it for these lights at colours. Have you got photo of your drawings? Our cabinets already made and get fitted tomorrow, I’m worried! Re: Building Arden homes Votivo 37 in South East 473Aug 19, 2018 2:10 pm So had a visit today and met SS regarding frame completion date - he showed the photos taken on 21/05/18 of work done. Have been told that PCI May be around 27:05/28 and can expect handover a week after Carpet is in Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Laundry benchtop Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Common bath Spa done and shower at 1200x1200 looks good size Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ a But the problem is regarding master ensuite BIR wherein we missed to check the height of shelf and it is glued to the plaster - so a problem here how to move it Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then I saw this - the downlights supposed to go inside the cabinet but the electricians put it this way Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hey PEast, is this correct for under cabinet lighting? We have asked for the same but this is absolutely not what we asked for. I thought that they would be recessed into the cabinets? We asked for the same as well, but can't find any reference to it being recessed anywhere on my plans or contract. Will need to confirm with my CSA. Let me know Daz as I’m in same boat as you except our cabinets go in Tuesday ![]() Re: Building Arden homes Votivo 37 in South East 474Aug 19, 2018 3:29 pm Ezza The V shown is the place for under cabinets. They still have to put false shelf for the cabinets. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 475Aug 19, 2018 9:38 pm And then I saw this - can’t underdtand why smoke detector is not white. If I have chosen white downlights then this turns out yellow - don’t remember being asked it’s colour Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Re: Building Arden homes Votivo 37 in South East 476Aug 19, 2018 9:39 pm It's a cover, it'll be removed. Re: Building Arden homes Votivo 37 in South East 477Aug 19, 2018 9:41 pm Re: Building Arden homes Votivo 37 in South East 479Aug 19, 2018 9:45 pm blackcat20It's a cover, it'll be removed. Cover for smoke detector or for the downlight under the cabinetry? Re: Building Arden homes Votivo 37 in South East 480Aug 19, 2018 10:03 pm follow my build Arden homes Votivo 37 iin south east: https://forum.homeone.com.au/viewtopic.php?f=31&t=88622 Oof, that sounds like a classic East Brisbane curveball. Underground utilities can really throw a wrench into even the simplest builds. Have you looked into whether… 3 40929 Old Home Restoration / Renovation Thanks for the reply. I just moved to Melbourne so unfortunately don’t know many people around. Hence came to this forum hoping to find someone who had some feedback… 2 2337 Where are you located? Assuming Sydney or south? Speaking from experience, big windows create significant heat gain/loss even if they're double/triple glazed. I do still… 1 31615 |
