After all advices, I think I am going to use hydronic heating for my house because allergies. Are there any advice who is the best installation for this system.
Thank you All.
Phan
Browse Forums Heating, Cooling & Insulation Re: Hydronic heating 5Jul 04, 2018 4:21 am Freezing: Hydronic heating systems make use of piping to move hot water to radiators throughout your home. If the temperature drops and the pipes still have water in them, they can freeze and burst, which can require significant and costly repairs. However, this can be easily offset by properly insulating your pipes before the winter season occurs. Single Purpose: Many forced air central heating systems operate as both furnaces and air conditioning units. Hydronic heating systems, usually in the form of boilers, cannot provide your home with cooling in the summer months, which means that you will have to have an air conditioning system installed in tandem with your hydronic heating system, an additional cost. Re: Hydronic heating 6Jul 04, 2018 9:17 am Hfranco2018 Freezing: Hydronic heating systems make use of piping to move hot water to radiators throughout your home. If the temperature drops and the pipes still have water in them, they can freeze and burst, which can require significant and costly repairs. However, this can be easily offset by properly insulating your pipes before the winter season occurs. Single Purpose: Many forced air central heating systems operate as both furnaces and air conditioning units. Hydronic heating systems, usually in the form of boilers, cannot provide your home with cooling in the summer months, which means that you will have to have an air conditioning system installed in tandem with your hydronic heating system, an additional cost. Thank you so much for your advice! Does anyone have a suggestion for a good hydronic in slab heating speacialist who may be able to help me with an existing system and wether or not it may need a seperator… 0 5508 Currently renovating, and our main lounge is 5m x 10m, with a cathedral roof peaking at 6.5m high. Currently have tiles on concrete slab. Room is very hard to heat. I am… 0 5404 Hi All, Our current 16 year old ducted gas heating is broken and needs an urgent replacement and appreciate any advise from the industry experts to make a decision for… 0 3820 |
