Browse Forums Building A New House Re: Coral Homes - Modified Grange 29 297May 29, 2018 7:50 pm Lot126Your home is lovely! How nice are Freedom's s-folds, I've had them bookmarked for ages! With your stacker doors, does the track go around the corner or do you have two separate tracks meeting in the middle? It looks seamless! Thank you so much๐ nope, i just butted the tracks up together. Its quite easy to do. Also, the pre made tracks weren't the right size to fit our stackers, so we bought a longer length and hubby cut them to size. Saved us buying a custom made track at over double the cost ๐ Re: Coral Homes - Modified Grange 29 298May 29, 2018 8:43 pm Dylandbrooke Lot126Your home is lovely! How nice are Freedom's s-folds, I've had them bookmarked for ages! With your stacker doors, does the track go around the corner or do you have two separate tracks meeting in the middle? It looks seamless! Thank you so much nope, i just butted the tracks up together. Its quite easy to do.Also, the pre made tracks weren't the right size to fit our stackers, so we bought a longer length and hubby cut them to size. Saved us buying a custom made track at over double the cost ![]() ~ Emma Re: Coral Homes - Modified Grange 29 299May 29, 2018 9:15 pm A couple more pics while my house is tidy ๐
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Most builders will provide standard Island Bench with overhang. Can these standard island bench be modified to some of the ones shown in display houses? Or it is a case… 0 23360 unable to read all the dimensions but if the block is 24m wide why is the house only about 16m wide and garage on boundary? are there any good or bad views, what is the… 1 8249 For those thinking about building with Coral - Rotated through 5 different supervisors - Had to personally point out missing/wrong items during the building process -… 0 26443 |
