This is standard. We went into wardrobe showrooms before signing contract to look at upgrade pricing and they warned us to delete all fittings if we wanted double hanging as the height would be wrong.
Browse Forums Building A New House Re: Building with Wisdom Homes 10822May 17, 2018 11:57 pm navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Building with Wisdom Homes 10824May 18, 2018 12:25 pm BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Building with Wisdom Homes 10827May 18, 2018 10:09 pm Aside from deleting the wardrobes as mentioned above, a few more words of wisdom from me for those yet to finalise selections... If you have 2590 ceilings and 2340 doors, the gap between the architrave and cornice is small and therefore easily shows up if either isn’t totally square. Not something you’d notice unless you’ve built the home but still something that bugs me- houses aren’t perfect, get square set ceilings and then it isn’t at all noticeable. Check your bath mixer is positioned so you can reach it when you’re in the bath. Get downlight provisions. Our lights were $13 each, look great and I put them in myself. They are THAT easy I didn’t even need to ask hubby ha ha. Position an aircon control panel in the area you will be cooling/heating most often, as it reads the temperature. Ours is in the hallway which is not part of the zone we use most often and therefore it just blasts out the heat continually in that zone rather than switching off when it gets hot enough. The standard appliances and showerheads are really good. Very glad we didn’t spend money upgrading them. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 10828May 19, 2018 8:37 am MandM+4 Aside from deleting the wardrobes as mentioned above, a few more words of wisdom from me for those yet to finalise selections... If you have 2590 ceilings and 2340 doors, the gap between the architrave and cornice is small and therefore easily shows up if either isn’t totally square. Not something you’d notice unless you’ve built the home but still something that bugs me- houses aren’t perfect, get square set ceilings and then it isn’t at all noticeable. Check your bath mixer is positioned so you can reach it when you’re in the bath. Get downlight provisions. Our lights were $13 each, look great and I put them in myself. They are THAT easy I didn’t even need to ask hubby ha ha. Position an aircon control panel in the area you will be cooling/heating most often, as it reads the temperature. Ours is in the hallway which is not part of the zone we use most often and therefore it just blasts out the heat continually in that zone rather than switching off when it gets hot enough. The standard appliances and showerheads are really good. Very glad we didn’t spend money upgrading them. Thank you for the tips MandM+4 !! We have 2.74m high ceilings on the ground floor and also got square set. I think the $990 definitely is worth it. However, we have the standard ceiling height for the first floor and sometimes i wonder whether we should have upgraded to the 2.59m. At the time, hubby and i decided not to - we are both NOT tall at all We got downlight provisions, but get 15 free as per the promo. Do we need to get EXACT same ones as Clipsal provides so it's all consistent or are they pretty much standard/look the same? Good point about the aircon control. Will have to remember that! Our Colours Consultant is pretty much ready to finalise our paperwork, however Ultra Air is keeping things at a standstill. Still waiting on documentation so i can sign off on them. Do they usually take awhile to get a Quote ready? Re: Building with Wisdom Homes 10829May 19, 2018 9:09 am MandM+4 Aside from deleting the wardrobes as mentioned above, a few more words of wisdom from me for those yet to finalise selections... If you have 2590 ceilings and 2340 doors, the gap between the architrave and cornice is small and therefore easily shows up if either isn’t totally square. Not something you’d notice unless you’ve built the home but still something that bugs me- houses aren’t perfect, get square set ceilings and then it isn’t at all noticeable. Check your bath mixer is positioned so you can reach it when you’re in the bath. Get downlight provisions. Our lights were $13 each, look great and I put them in myself. They are THAT easy I didn’t even need to ask hubby ha ha. Position an aircon control panel in the area you will be cooling/heating most often, as it reads the temperature. Ours is in the hallway which is not part of the zone we use most often and therefore it just blasts out the heat continually in that zone rather than switching off when it gets hot enough. The standard appliances and showerheads are really good. Very glad we didn’t spend money upgrading them. A very good one which I picked too and corrected it to a lower position for reach. [i][i][i]Building Ambassador 41 Wisdom Homes[/i][/i][/i] Re: Building with Wisdom Homes 10830May 19, 2018 11:35 am I would also suggest square set ceilings to all downstairs to avoid the cornices finishing oddly as they hit the lowered kitchen ceiling part (which is square set) or the coffered hallway ceilings (also square set). majestic35.weebly.com Re: Building with Wisdom Homes 10831May 19, 2018 12:10 pm Kvav27 That's a golden question, thanks for reminding me. I will try that next week and see what my SS can promise me. Navy navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: Building with Wisdom Homes 10832May 20, 2018 1:02 pm hi All, need advise, I went to see the slab and it feels tilted. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Kindly advise Tia BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Re: Building with Wisdom Homes 10833May 20, 2018 7:56 pm MandM+4 Aside from deleting the wardrobes as mentioned above, a few more words of wisdom from me for those yet to finalise selections... If you have 2590 ceilings and 2340 doors, the gap between the architrave and cornice is small and therefore easily shows up if either isn’t totally square. Not something you’d notice unless you’ve built the home but still something that bugs me- houses aren’t perfect, get square set ceilings and then it isn’t at all noticeable. Check your bath mixer is positioned so you can reach it when you’re in the bath. Get downlight provisions. Our lights were $13 each, look great and I put them in myself. They are THAT easy I didn’t even need to ask hubby ha ha. Position an aircon control panel in the area you will be cooling/heating most often, as it reads the temperature. Ours is in the hallway which is not part of the zone we use most often and therefore it just blasts out the heat continually in that zone rather than switching off when it gets hot enough. The standard appliances and showerheads are really good. Very glad we didn’t spend money upgrading them. Thanks for the extra tips! You've made my mind up about the down light provisions. I was worried it would be too much effort. I'm currently in CDC but able to update my electrical plan since I had plan changes so I'm re-looking at everything. I might change them to all provisions now to save some $$$. I did want to ask if anyone had some tips on the home theatre electrical set up? I've currently got the bullnose plates for the moutning, double power point and one data point. Would that suffice? Is it easy to put the wires through the bullnose plates? I'm worried because we have soundproofing it would be difficult to do the wires so considering adding HDMI cables although the are pricey as we'd need more than one! Any advice would be much appreciated. Re: Building with Wisdom Homes 10834May 20, 2018 9:02 pm ASJ1981 MandM+4 Aside from deleting the wardrobes as mentioned above, a few more words of wisdom from me for those yet to finalise selections... If you have 2590 ceilings and 2340 doors, the gap between the architrave and cornice is small and therefore easily shows up if either isn’t totally square. Not something you’d notice unless you’ve built the home but still something that bugs me- houses aren’t perfect, get square set ceilings and then it isn’t at all noticeable. Check your bath mixer is positioned so you can reach it when you’re in the bath. Get downlight provisions. Our lights were $13 each, look great and I put them in myself. They are THAT easy I didn’t even need to ask hubby ha ha. Position an aircon control panel in the area you will be cooling/heating most often, as it reads the temperature. Ours is in the hallway which is not part of the zone we use most often and therefore it just blasts out the heat continually in that zone rather than switching off when it gets hot enough. The standard appliances and showerheads are really good. Very glad we didn’t spend money upgrading them. Thank you for the tips MandM+4 !! We have 2.74m high ceilings on the ground floor and also got square set. I think the $990 definitely is worth it. However, we have the standard ceiling height for the first floor and sometimes i wonder whether we should have upgraded to the 2.59m. At the time, hubby and i decided not to - we are both NOT tall at all We got downlight provisions, but get 15 free as per the promo. Do we need to get EXACT same ones as Clipsal provides so it's all consistent or are they pretty much standard/look the same? Good point about the aircon control. Will have to remember that! Our Colours Consultant is pretty much ready to finalise our paperwork, however Ultra Air is keeping things at a standstill. Still waiting on documentation so i can sign off on them. Do they usually take awhile to get a Quote ready? Hmm not sure about the aircon as back when I did selections we did aircon, kitchen and tile appointments months before the others. We have standard ceilings upstairs and it’s totally fine. Our upstairs looks pretty basic compared to downstairs, but I don’t regret that. The downlights we bought are a bit different to the Clipsal ones, actually they look better lol, but it’s not something people would really notice. We just made sure they were switchable like the Clipsal ones as we have them all on the daylight setting at the moment but may want to change them in the future. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 10835May 20, 2018 9:04 pm It does look funny in the pics but I’m sure they would pour it level. Maybe put a spirit level on it to ease your mind. Building Monte Carlo 40- Wisdom homes Re: Building with Wisdom Homes 10838May 20, 2018 11:38 pm Rocchet Chompy Rocchet [quote="psur2357"]hi all, i found that the installed walk in robe top shelf is at 1.8 m above the floor. Apparently this is wisdom home standard when I checked with Stylish wardrobe who is doing the install. This is very strange as the industry standard is at 1.95 m so that we can have the top rod and bottom clothing rod. Has anyone had this issue before?? This is standard. We went into wardrobe showrooms before signing contract to look at upgrade pricing and they warned us to delete all fittings if we wanted double hanging as the height would be wrong. Ricochet-does that mean you went external? Yes we got credits for removing all wardrobe shelving and did it after handover. That way we got exactly what we wanted and it was cheaper. [/quote]Hi, What is the value of the credit? And isn't it the kitchen guys that don't all the cabinetry? Don't you simply ask for the 1.95m top shelf instead of 1.8m? Re: Building with Wisdom Homes 10839May 20, 2018 11:42 pm singalg ajayshekar in one word: Stunning!! Congratulations!! Enjoying moving in now Nice! What size is your balcony and which suburb are you in? Re: Building with Wisdom Homes 10840May 21, 2018 12:16 am GLO Rocchet Chompy [quote="Rocchet"][quote="psur2357"]hi all, i found that the installed walk in robe top shelf is at 1.8 m above the floor. Apparently this is wisdom home standard when I checked with Stylish wardrobe who is doing the install. This is very strange as the industry standard is at 1.95 m so that we can have the top rod and bottom clothing rod. Has anyone had this issue before?? This is standard. We went into wardrobe showrooms before signing contract to look at upgrade pricing and they warned us to delete all fittings if we wanted double hanging as the height would be wrong. Ricochet-does that mean you went external? Yes we got credits for removing all wardrobe shelving and did it after handover. That way we got exactly what we wanted and it was cheaper. [/quote]Hi, What is the value of the credit? And isn't it the kitchen guys that don't all the cabinetry? Don't you simply ask for the 1.95m top shelf instead of 1.8m? [/quote] I’ll see if I can dig out my tender with the credit price. Although it wasn’t much from memory. No kitchen guys dont do shelving. Cupboard fitouts and shelving including the pantry shelving are done by a different company. We didn’t ask about changing height of the shelves as we wanted to do a complete design and fitout ourselves with shelving, drawers, shoe holders etc... so was always going to be cheaper afterwards (and easy) I’m sure they can do it if requested. Just keep in mind the need to raise any cupboard door heights (that aren’t walkins) to ensure access to top shelves. We forgot with one wardrobe but our installer designed a narrower top shelf so we could still get things up there. majestic35.weebly.com Can someone please offer some advice? Im DESPERATE. Because I'm completely and utterly exhausted. How long are variations taking with other companies at the moment? We… 0 19235 In fairness nobody gave a crap about the ACCC and the gag clauses continued in the pro forma templates of a few other builders after the ACCC took on Wisdom, and more… 19 74732 Hi Everyone, I am exploring builder in NSW and received a very tempting quote from Wisdom home for their momentum series. I just want to know experience of building… 0 9703 |
