Browse Forums Building A New House Re: Building with Hall & Hart Homes 214May 16, 2018 9:28 pm We got our tender revisions back today. We requested the increase in ground floor ceiling height to 2750mm and because of that asked for increase in height to garage and alfresco. HHH were confused by this request and now I'm confused too. I thought this was to increase the garage door and alfresco door height to match the increased ceiling height, is this correct? Seren1ty, I think you had a variation to increase the garage and alfresco as well, do you remember how this was worded in your tender? Also, what kind of cavity sliding doors did you and kjane select? I think kjane mentioned cost of the CSD she got was about $350. We got our quote back at $450 for a single 2040mm high x 720mm wide CSD - just want to compare to the ones you guys selected? Thanks for your help! Re: Building with Hall & Hart Homes 215May 16, 2018 11:51 pm Hi Zen, good to hear that you got the tender back and hope the sticker shock was not too bad. We raised the ground floor ceiling height to 2750mm from the promotion (value as per promotion $3,999) and also "raised head height to ground floor windows and sliding/stacker doors" to 2400mm also from the promotion (value as per promotion $1,999). So that covers all windows and alfresco doors on the ground floor. As an addition we increased the garage door height to 2400mm in lieu of standard which cost $450. Hope this makes sense, happy to try to clarify further if it doesn't. We put in a few CSD's, the one for the main bathroom entry (2040mm high x 820mm wide) in lieu of opening was $450. I'm gathering this was more expensive as there was no door there originally. CSD to laundry (2340mm high x 820mm wide) in lieu of hinged door was $200. CSD to ensuite (2040mm high x 820mm wide) in lieu of hinged door was $200. Sorry, when I wrote $350 I think I looked at the price for something else. Where are you planning to put the door? Re: Building with Hall & Hart Homes 216May 17, 2018 12:01 am Quick question for you Seren1ty, when you had your floorboards laid did the edges go under the skirting boards so its just floorboards and skirting boards or did they need to put wood at the base of the skirting board on top of the floorboards where they meet? I'm sorry if this makes no sense at all, I tried to look at your flooring photo but now can't seem to find them on the thread. Wish I knew some more building jargon sometimes! Re: Building with Hall & Hart Homes 217May 17, 2018 8:41 am kjane Quick question for you Seren1ty, when you had your floorboards laid did the edges go under the skirting boards so its just floorboards and skirting boards or did they need to put wood at the base of the skirting board on top of the floorboards where they meet? I'm sorry if this makes no sense at all, I tried to look at your flooring photo but now can't seem to find them on the thread. Wish I knew some more building jargon sometimes! My 2 cents and I am not Seren1ty or expert - If the flooring is done by builder then he will ensure that skirting is fixed after the flooring is done. Often they 'tack' the skirting so it can be effortlessly removed while flooring is installed. Then the skirting is firmly nailed in. Where installing skirting after floor lay is not possible then 'scotia' is used along the join. If you choose to install Luxury Vinyl Planks, then those are cut to the edge, so scotia or installing skirting after flooring is not required. Trim is installed where 2 types of floorings (say carpet and timber) meet. Trim is also used in places where there is difference in adjoining floor heights. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Building with Hall & Hart Homes 219May 17, 2018 11:33 am kjane Hi Zen, good to hear that you got the tender back and hope the sticker shock was not too bad. We raised the ground floor ceiling height to 2750mm from the promotion (value as per promotion $3,999) and also "raised head height to ground floor windows and sliding/stacker doors" to 2400mm also from the promotion (value as per promotion $1,999). So that covers all windows and alfresco doors on the ground floor. As an addition we increased the garage door height to 2400mm in lieu of standard which cost $450. Hope this makes sense, happy to try to clarify further if it doesn't. We put in a few CSD's, the one for the main bathroom entry (2040mm high x 820mm wide) in lieu of opening was $450. I'm gathering this was more expensive as there was no door there originally. CSD to laundry (2340mm high x 820mm wide) in lieu of hinged door was $200. CSD to ensuite (2040mm high x 820mm wide) in lieu of hinged door was $200. Sorry, when I wrote $350 I think I looked at the price for something else. Where are you planning to put the door? Thanks so much, kjane! Exactly the wording I was after. Our deadline for tender acceptance is tomorrow so I've sent the updates back. Our additional requests have added an extra ~$40k to the original tender a week ago and that's before internal selections.... ouch! My husband and I are debating on what stays in or goes out, let's see who wins... We added 2 new CSDs, one between WIR and parents retreat (we modified the original Sienna floorplan so the WIR is between the master bed and the retreat) - that one is 450 and the other CSD is in the ground floor rumpus, slightly wider so that came back at $490. Makes sense these are more expensive since they are new doors, thanks for helping us muddle through this! Re: Building with Hall & Hart Homes 220May 17, 2018 11:45 am No worries It's hard to pull it back, we ended up needing to drop about 20K to get it to a not so eye watering amount. I had to try to control my husband more so than me, he was like Oprah at the internal selections "upgrades for everyone!!!" Before I call the council hoping you might know the answer (and save me being on hold on an international call for an hour!). I was reading in the paper today that Ryde council is stopping the processing of development applications https://www.smh.com.au/national/nsw/developers-hit-back-against-state-government-housing-pause-20180516-p4zfpk.html . Do you know if that applies to knock down rebuilds/single homes or is it just for large scale developments? Really hoping it doesn't apply to us... I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 9334 I would never build with Fowler homes. I built with them in 2021 and till date maintenance issues are pending. All their existing trades and businesses don't work with… 14 109690 Hi there! Putting the feelers out there for those who have (or almost) built with Arli homes! Interested in your experiences who've built from their stock home designs… 0 26677 |
