Browse Forums Landscape & Garden Design Re: What is this - storm water drain? 2Feb 13, 2018 9:32 am Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: What is this - storm water drain? 9Feb 20, 2018 9:14 am Jeeta23 Ezza78 Jeeta23 [quote="building-expert"]if you have six of them they would be stormwater, check against your drawings for layout of stormwater drains to confirm. Yes grade your surface levels toward the drain, cut it and fit prefab plastic drain pit at the lowest point. Another way to tell would be to measure the diameter. Stormwater is 90mm ,sewer 100 although some stormwater is laid in 100mm. Thanks for that - I will now go ahead and buy appropriate storm water pits for the pipes. Appreciate your help! But isn’t the stormwater channeled to the legal point of discharge? Eg. Front curb drain? Hi Ezza, It may differ from my area to your (as your one was a KDR), I can confirm mine is connected to the underground storm water discharge for our estate.[/quote] Thanks Jeeta, do it’s like the storm water drainage is set up, we just have to finish it with our landscaping. So we can direct water to the storm water drains? Thanks heaps Re: What is this - storm water drain? 10Feb 20, 2018 9:31 am Ezza78 Jeeta23 Hi Ezza, It may differ from my area to your (as your one was a KDR), I can confirm mine is connected to the underground storm water discharge for our estate. Thanks Jeeta, do it’s like the storm water drainage is set up, we just have to finish it with our landscaping. So we can direct water to the storm water drains? Thanks heaps No worries Yes, essentially that what it is - a storm water drainage system for property. If it is done the right way, it will protect your slab from water issues too. Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 8196 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 7078 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10850 |
